Old 05-07-2009, 09:40 AM   #1
64_twins
silly questions?
I have replaced the outer floor pans in my 64 chevy. There are drain holes? in the new pans. Are there plugs out there for these or am I going to have to fill them?
Also, when looking from the inside of truck down into the cab corner I can still see the ground even after replacing pans, corners, rockers, etc... I'm not real crazy about the elements having such easy access into the cab. Is there a trick to closing this in or is it supposed to have a gap there?
64_twins is offline   Reply With Quote
Old 05-07-2009, 10:01 AM   #2
jason65
Registerd User
jason65's Avatar
Re: silly questions?
Welcome and got any pics? So we can see what your talking about.
jason65 is offline   Reply With Quote
Old 05-07-2009, 11:11 AM   #3
64_twins
I can get some pics of the cab corner space later today. The actual outer floorpan shows the holes in the LMC catalog but the factory pan didn't have these.
Old 05-07-2009, 11:14 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I havent had to purchase these parts, but they arent the holes for the sill plates, are they? 6 holes in a straight line roughly an inch away from the weather strip? Just a thought.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-07-2009, 11:19 AM   #5
64_twins
A good thought but not the case. These are two holes at the back edge of the floor pan up on the hump part. They are about 1" in diameter. Unfortuantely I will have to drill the sill plate holes.
Old 05-08-2009, 08:45 AM   #6
64GMCHorsepower
Justified!
Who did you buy the pans from?
I don't remember any holes in the ones I bought....
You might just have to patch them....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 05-11-2009, 08:06 AM   #7
64_twins
Bought the panels from LMC. I guess I will try and plug them. The rocker panel plug fits the larger hole. I'm probably just missing something stupid here but they look to be drain holes of some kind. Page 16 of the LMC catalog has the outer floor panel, number 4, it shows the two holes. I never paid any attention until I started putting them in.
Old 05-11-2009, 11:04 AM   #8
protrash64
protrash64's Avatar
Thats a factory hole; my truck has those in the pan. I dont know what they are for, seat belt? Tightening an exhaust clamp? At least when you drill the sill plate holes, you know they will work.....my 'burb has them rotted out a bit so Im going to use bolts and nuts.....
Old 05-11-2009, 11:21 AM   #9
chevroletrestoguy
I bought those panels too and I think the holes are only on the drivers side. I say that you could either get some rubber plugs or just weld them up. As far as the holes in the cab corners, I believe they were manufactured like that because the gas tank is in that area and then the cover goes over the gas tank. Maybe the holes are there for safety reasons? I may be wrong but that's my theory.
chevroletrestoguy is offline   Reply With Quote
