Old 05-07-2009, 10:07 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
clock install for gauge cluster
I'm looking for someone who has done the clock install in their gauge pod. I can't find a FAQ on the wsubject and if anyone has pics and how to , it would be great-Thanks
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 05-07-2009, 10:34 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: clock install for gauge cluster
There's been some guys that have done it. Maybe a search on this forum might help you.
I've been looking for one to intall on my 68 GMC. The aftermarket ones I've seen all have the bowtie or Chevy/chevrolet markings on them. I'm looking for a generic one.
68gmsee is offline   Reply With Quote
Old 05-07-2009, 10:53 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
http://67-72chevytrucks.com/vboard/s...ghlight=clocks
http://67-72chevytrucks.com/vboard/s...ghlight=gauges
There's probably more. Search (advanced) for clock, going back a year in "all open forums".
ETsC10 is offline   Reply With Quote
Old 05-07-2009, 01:26 PM   #4
mrein3
mrein3's Avatar
The first picture in in the first of the two links that ETsC10 posted is my truck.
I pulled the clock out of a mid 80's Suburban. The yard charged me around $5. It has two wires coming out of the back. One is black the other if I remember correctly is orange.
On your bench test the clock with a battery. Orange on + and black on -.
If it works, pull your dash bezel and disassemble it.
In the open hole (the one that is a vacuum or air gauge on bigger trucks), install the clock. Run the orange wire to an always hot terminal on the fuse block through an in-line fuse holder.
I learned how to make the hole in the clear plastic of the bezel on this forum. Drilling will probably crack the old plastic. Measure twice then heat up a nail with a propane torch or cigarette lighter and use it to "melt" a hole.
Plastic polish to remove the factory painted markings on that soon to be formerly open hole and put it all back together.
I have photos of when I did the work only they are not on this computer. If there is interest I'll find them and post 'em here.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-07-2009, 08:06 PM   #5
Andy4639
Old member
Andy4639's Avatar
Installed mine years ago out of a later 73 up model truck. No wires just spade connectors on the back of the clock. Hot wire ground and your done. Drill a small hole through the lens for the stem and mount it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-07-2009, 08:22 PM   #6
jay-dawg
chevelito
jay-dawg's Avatar
that's pretty trick...1 to file away on my computer.
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
