Old 05-07-2009, 10:30 AM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
How to tell if i have posi track
i think i might have a posi track, how can i tell? it might have been installed later also
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-07-2009, 11:56 AM   #2
monte0185
monte0185's Avatar
Re: How to tell if i have posi track
Jack up the rear end and put the truck in nuetral. Spin one tire and if the other spins the same way its Posi. If it spins backwards then its just a single wheel drive. Thats the easiest way.
Now if the clutches are worn out then it could potentially spin the other wheel backwards like a single track so the only true way is to pull the diff cover. But generally the first works pretty well.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 05-07-2009, 12:05 PM   #3
chevellelover
chevellelover
chevellelover's Avatar
have you ever done a burnout in it? Thats how i figured out mine didnt ahave a posi.
1978 Trans Am 400/4speed Year One Snowflakes
1980 c10 shortbed
1999 Suburban 5/7 drop US Mags Roadsters
1999 GMC Sierra Classic 4x4-MINT
2015 Challenger Scat Pack 6.4 8 Speed
chevellelover is offline   Reply With Quote
Old 05-07-2009, 12:12 PM   #4
ZombieWeinerDog
i havent done any hardcore burnouts, but i have done little Squeaks.
1972 longbed- 454
1967 shortbed- 355
Old 05-07-2009, 12:13 PM   #5
Normy71
What is involved in adding posi to a 12 bolt rearend?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 05-07-2009, 01:56 PM   #6
monte0185
monte0185's Avatar
Not alot. Just buy the correct posi carrier and a shim kit and install it. Read up on how to shim it though. They say to use a dial indicator but its not completely necessary. Just paint the gears with some of the marking paint Shim till you have just a tiny but of play up and down on the ring gear tighten it down run the gears around and check the wear pattern from the paint you put on and if its to tight or loose shim accordingly. Now take in mind this is a brief abbreviated version of this but basically its whats involved.
