Old 05-07-2009, 11:40 AM   #1
Green Machine
Green Machine's Avatar
Found a better hanger bearing - fairly cheap !!
Got this from NAPA - HB206FF - about $45.
They also carry the cheap one - PHB206FF - about $20.
(Or you can get a billet aluminum one with a poly insert from Inland Empire for about $120 )
This is what I found with the HB206FF vs the cheap ones -
A. The metal body appears to be heavier gauge than the cheap ones.
B. The metal body is welded to the top part at the sides along with the standard spot welds so it can't come apart there like the cheaper ones.
C. The bearing is much better qualility and a better brand name than the cheap ones.
D. Perhaps the most important difference - The rubber is much stiffer and should be less likely to get all sloppy in there like the cheap rubber does after a few miles.
E. Appears to come with better quality harder bolts, not the grade 2 bolts that come with the cheap ones.
The flat washers that come with the good bearing should be replaced as they are too small for the slotted mount on the frame and the bolts are METRIC so don't try to reuse the stock 3/8 bolts from the old beairng.
Hope this helps someone, they can be a pain to change. I think the better one is worth twice the price of the cheap ones.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-07-2009, 11:52 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Found a better hanger bearing - fairly cheap !!
Thanks for the info Green!!!....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-07-2009, 11:52 AM   #3
gintaras
Well that is an interesting observation about the rubber.. because the NAPA parts guy told me that the rubber and the housing was the same between the 2, and the only difference was the bearing itself, the cheaper bearing made in China..
If the rubbber is actually stiffer, tI wish I woul dhave known that before I installed the cheap one yesterday.
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 05-07-2009, 02:03 PM   #4
Green Machine
Well, I hope I am right about the rubber, kind of going from memory here, please feel free to comment, I could be FOS, hope not though.
Old 05-07-2009, 04:17 PM   #5
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
ive ran both of them the rubber feels about the same too me
tucnnuts is offline   Reply With Quote
Old 05-07-2009, 04:35 PM   #6
lofly'a
lofly'a's Avatar
good info, thanks.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 04-26-2010, 06:42 PM   #7
D-Rat
D-Rat's Avatar
digging up an old thread, but this is the one on my truck and it broke off clean right at the T mounting point.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
