Old 05-07-2009, 07:20 PM   #1
yodi
yodi's Avatar
59' 4x4 conversion
i have a 2wd 1959 Chevy apache, i want it to have a serious lift, and 4 wheel drive, i already know that no one actually sells anything close to what i am trying to do, so a chasis switch would problably be in order, but i was wondering if there was any other way to do it. just need some help. THANKS
p.s. if it makes any difference i still got the stock 270 with 4 speed granny, everything basicly stock
yodi is offline   Reply With Quote
Old 05-08-2009, 10:29 AM   #2
Burt4x4
Burt4x4's Avatar
Re: 59' 4x4 conversion
Were there is a will there is a way!
cut/chop/modify/weld/build/mount/sweat/bleed/ect... after all that Get-r-dirty!
ahahaha
If you need a fabrication shop with a Plazma cutting table and the knowladge to make that happen I would check out www.pacificfab.net they are just south of you in Morgan Hill. Top Shelf A+ work. They build street rods, 4x4s, custom whatever you need. The owner will be driving in the 4Wheel & Off Road Ultamate Adventure this year. (if you read thoes mags)
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-08-2009, 10:53 PM   #3
Mudder
Mudder's Avatar
They a presently disscussing this type of swap in the 4x4 area. I beleive this thread has just been moved here to 4x4. Look around here for that thread and I think you will be able to get some info there.
Mudder is offline   Reply With Quote
