exhaust size???
ok iv kinda been checking out different builds on here and lookin for exhaust kits
my question is i see alot of 2.5 in kits and 2.25 kits on here and alot of people using them i was just wondering if any one is using 3 in and if not why not |
#2 | |
Re: exhaust size???
I'd go at least 2.5". I don't think there's anything wrong with 3", especially if it's bent bent up with an exhaust pipe bender (as opposed to mandrel bends...) Pipe size does make a difference, but it largely depends on what you have under the hood. |
![]() Join Date: Feb 2001
Re: exhaust size???
On my 402BB Curt went with 2 1/2" and said 3" would be a bad idea. I'm not sure why but he has been in the resto business for about 35 years so it was ok with me. I'll let others chime in.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
![]() Join Date: Apr 2008
Re: exhaust size???
Unless you are building a high reving or really big inch motor 3 ince is overkill.
Between Trucks...
Re: exhaust size???
You'll lose a lot of low end torque with a 3" setup. Exhaust velocity will be actually higher with 2 1/2"
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 05-08-2009 at 09:03 AM. |
Re: exhaust size???
Listen to Sinister. The dude knows what he's talking about. I have a fairly built 350 with dual 2 1/2 inch Magnaflow exhaust with an H pipe. It is a perfect balance for the motor. If you're running single exhaust (not sure why you would), then I'd run a single 3".
Another good reason NOT to own a Ford of a similar year; try running dual exhaust on a Ford. The undercarriage is so full of crap that it's dang near impossible! Gas tank's in the way, no room in the frame rails, etc... |
Re: exhaust size???
Well I'm kind of bummed.. I just got a new exhaust yesterday and they told me that they couldn't do a 2 1/2" because the manifolds were only 2". THey gave me a 2 1/4" from the manifolds all the way back. WHy would an exhaust shop tell me this? To save $$ ??
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 ![]() 2001.5 VW Passat beater 1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint ![]() |
Re: exhaust size???
I have dual 3" coming right off the 3" collectors straight back and cut off before the axle. Has a 383 stroker now but I figured 3" leaves me plenty of room to 'expand' down the road.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap -- '84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast |
Re: exhaust size???
ok so basically my truck is gonna be used pretty much for towing its got a 402bb in it right now thats stock headers exhaust are pretty much all i want to do for now so 2.5 in exhaust would be better than the 3 in from what im seeing every one is saying
and yes pplanning on dual exhaust next question what does an h pipe or x pipe actually do whats the differance and how will it benifit me im new to this v8 stuff sorry for all the dumb questions Last edited by 84socal; 05-08-2009 at 12:37 PM. |
Re: exhaust size???
Like I mentioned earlier, it depends on what kind of bends are being used to make it.
3" pipe with non-mandrel bends will be crushed down to about 2.5" at the bends. Your exhaust can only flow as good as the smallest point. |
Re: exhaust size???
Fully built 406 and I have 2 1/2 exhaust and it works perfect...
Unless you are building a full race 14:1 compression motor I would stay away for anything bigger.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Loving the Jimmster
Re: exhaust size???
What is the standard size on these trucks??
#13 |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: exhaust size???
Here is a really good article I read about the X vs H pipe a while back.
http://www.carcraft.com/techarticles...ion/index.html I have a mildly built 402 with full length headers, x pipe , 2.5" pipe and Flowmasters It performs really well and gets very loud when you open it up. I also stuck the mufflers under the bed and piped it out the back to keep cab noise down.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
#14 |
![]() Join Date: May 2002
Re: exhaust size???
most of the difference has to do with the amount of backpressure your engine uses to be efficient. too much and you loose hp (or the engine won't run at all). too little, and you loose torque.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 05-08-2009 at 01:21 PM. |
#15 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: exhaust size???
They did you fine. Like they said, your manifolds are 2 inch. It's pointless to run a 2.5 inch pipe behind a 2 inch manifold. The exhaust velocity would actually slow down when it hit the bigger pipe. For street driving, it's better to err smaller on exhaust size. This gives much better mileage and throttle response.
#16 |
![]() Join Date: Jan 2008
Re: exhaust size???
I run a 3" mandrel bent with an X-pipe.It works great with a 406, mechanical roller cam,Jesel shaft rockers and Victor Jr. heads. Unless you're making in excess of 500H.P., I'd go with 2.5". Remember,these are big air pumps and they do have to breathe.My .02,Good luck
