Old 05-08-2009, 06:16 AM   #1
eastcoastcivil
Question Edelbrock carb to manifold torque setting?
I took the carb off my truck to clean it thinking it was dirty when in fact it was fine, but I tore the gasket and have to replace it. Does anyone know the torque settings on the 4 bolts when I bolt the carb back on. I have an Edelbrock Performer aluminum intake and a 600 Performer carb. I just don't want to mess anything up. I think its between 25 and 30?? Anyone?
If your not living for something, your dieing for nothing...
eastcoastcivil is offline   Reply With Quote
Old 05-08-2009, 02:09 PM   #2
eastcoastcivil
Re: Edelbrock carb to manifold torque setting?
Does no answer mean everyone is still running Rochester 1 or 2 barrel carbs or was my question just really stupid? LOL
Old 05-08-2009, 02:17 PM   #3
ZombieWeinerDog
ZombieWeinerDog's Avatar
i have the same setup, but i suck at anything engine related. sorry
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-08-2009, 02:40 PM   #4
eastcoastcivil
Thanks anyways. Hey, what are you running for a fuel pump on your set up? I have to replace mine and I think it will just be a stock pump for a 1970.
Old 05-08-2009, 02:43 PM   #5
Jim_PA
Just a little more than snug. Check them after a week or so.
Jim_PA is offline   Reply With Quote
Old 05-08-2009, 02:54 PM   #6
Alex Hayley
The service manual says 14 ft lbs. I always do the "little more than snug" thing though.
Alex Hayley is offline   Reply With Quote
Old 05-08-2009, 03:20 PM   #7
cdowns
cdowns's Avatar
99.9% of all carbs i've worked on it's about imposible to get a torque wrench on them so i just go snug
Old 05-08-2009, 03:24 PM   #8
sjarrett71
sjarrett71's Avatar
I've never torqued a carb down and have always been fine with no leaks.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-08-2009, 04:23 PM   #9
threeDguru
threeDguru's Avatar
They say about 10-15 ft. lbs, no more no less
threeDguru is offline   Reply With Quote
Old 05-08-2009, 04:25 PM   #10
dimkapdx
My experience is that when you go into aluminum, you shouldn't do anything over 15lbs. Make sure to use some anti-sieze, too.
dimkapdx is offline   Reply With Quote
