05-08-2009, 10:59 AM | #1 |
65 drop spindles
Im looking to buy some drop spindles for my 65. The problem is, my truck already has disc brakes and i dont know what year conversion was used. Looks converted to original 65 but is there a easy way to identify what year ball joints used. I dont want to order the wrong spindle - help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
05-08-2009, 11:15 AM | #2 |
Re: 65 drop spindles
Drop a spindle and measure the ball joints.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 05-08-2009 at 11:16 AM. |
05-08-2009, 01:19 PM | #3 |
Watch out for your cornhole !
Answer a couple of questions for me.
1) Are your control arm bushings screw in metal type or rubber press in type. Look at them, do they look like a giant bolt head with a grease zerk in the middle or do they have a big washer and nut ? 2) Upper brake hoses, do they go to the frame rail in front of the crossmember, or to a tab on the front of the crossmemer, or to the rear of the crossmember ?
05-08-2009, 11:36 PM | #4 |
60-66 Nut
A pic or two would help as well. The dust shield on the inside of the rotor is different from '71-'72 versus the '73-'87's.....kind of hard to describe.
05-09-2009, 03:24 PM | #5 |
1. rubber with grease zerk
2. to the rear of crossmember |
05-09-2009, 11:48 PM | #6 |
60-66 Nut
The rubber bushings don't have grease zerks, but the older suspensions with the steel bushings have a grease zerk with rubber seal behind them. So assuming you have the older suspension, you either have a '71-'72 front suspension, or someone left the '65 suspension and swapped just the spindles, rotors, calipers, etc. Still hard to know exactly what spindles you have......pics?
