Old 05-08-2009, 12:37 PM   #1
420am
420am's Avatar
Can I remove the AC box and retain my heat?
My truck is missing everything for the AC other than the box on the firewall and the controls in the cab. The truck also has a newer engine in it with the alternator on the passenger side. Thinking about removing the box to clean up my firewall and I'm curious if that kills my heat somehow.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 05-08-2009, 12:46 PM   #2
sjarrett71
sjarrett71's Avatar
Re: Can I remove the AC box and retain my heat?
www.acdelete.com has what you need to retain your heat. A little expensive but cleans up the engine bay real good.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-08-2009, 12:51 PM   #3
420am
420am's Avatar
Cool. Thanks.. that is a little pricey though. Is there a DIY way to do it?
Old 05-08-2009, 01:03 PM   #4
sjarrett71
sjarrett71's Avatar
I'm sure if you had a sheetmetal brake and a little time you could get it done. I don't think I've seen one done yet though.
-Scott-
ac removal heat
