Old 05-08-2009, 12:53 PM   #1
JimmyFloyd
what 78 blazer parts fir my 70?
Found a 78 Blazer in the yard, and was wondering if there were some parts that would fit mine? It has an aux battery tray, power steering pump/lines, and top bolts that I am mainly interested in. The rear seat would be nice since mine didn't come with one. And would the gas tank and lines work if I can get them out? Thanks.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-08-2009, 01:01 PM   #2
muddobber
muddobber
Re: what 78 blazer parts fir my 70?
i tried a 78 tank in my 72 and it was wat to big it hit the rear dif.
muddobber is offline   Reply With Quote
Old 05-09-2009, 06:14 AM   #3
vtblazer
vtblazer's Avatar
Nothing will be a direct bolt in but if you wanna do some mods, most of it 'could'.
vtblazer is offline   Reply With Quote
Old 05-09-2009, 10:08 AM   #4
turp mcspray
turp mcspray's Avatar
Smile Re: what 78 blazer parts fir my 70?
I put a 31 gallon blazer tank in my 72. I used the front crossmember from a 73up blazer and moved my original rear crossmember back as far as it would go. Worked out great. Sure beats carrying a 5gallon can of spare gas along!
turp mcspray is offline   Reply With Quote
Old 05-09-2009, 01:15 PM   #5
muddobber
muddobber
disc brake front axle ,rear end , you just have to move the spring perches
Old 05-10-2009, 07:00 AM   #6
vtblazer
vtblazer's Avatar
Doesn't it hang down pretty low beneath the frame?
Would you consider it to be an option if the blazer was going to be used for wheeling?
