Old 05-08-2009, 04:02 PM   #1
jbutta224
Lowering a C-20
Does anybody have any information on who makes a lowering kit for my 1980 C-20. I have searched all over and i cant find a thing. You help would be appreciated thanks guys. josh
jbutta224 is offline   Reply With Quote
Old 05-09-2009, 07:35 AM   #2
jaycrew1
jaycrew1's Avatar
Re: Lowering a C-20
I also have a C-20, mine is a 1987. I lowered it using a kit that I purchased from Styling Concepts. There usually isn't much advertising for these kits as they are not as popular as the newer bodies style kits. The lowering package I bought included drop shackles for the rear leaf packs and lower control arms for the front. I also removed a couple of leaves from the rear, which softened the ride and lowered it a little more. The kit is made by DJM and is SUPER strong. The kit is called a 3-4 drop. However, I did modify the DJM control arms slightly, I cut off the steering stops because I could not turn the wheels very far in either direction. I still want to take the front down a couple of inches. I plan on using 1/2 ton coils or by cutting a 1 coil off of the original springs. I am running 20" wheels up front and 22" wheels out back, so I want to have sort of a raked look. Hope this helps. Check out http://www.djmsuspension.com/ for more product info.
jaycrew1 is offline   Reply With Quote
Old 05-11-2009, 12:25 AM   #3
pig rig
pig rig's Avatar
Re: Lowering a C-20
you can use 1 ton stuff but the spindles are different the difference is brake calipers and rotors
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
