Old 05-08-2009, 06:21 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Glass Run Channel
What's involved with replacing the glass run channel, you know the weather strip that goes at the back and top of the door window frame?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-08-2009, 06:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Glass Run Channel
You should be able to take the door inner panel off, roll the window down, pull the channel out and put in the new. The toughest area is where the rear of the window frame meets the door. It's a little tight there.
LockDoc
Leon
Old 05-08-2009, 07:09 PM   #3
JimKshortstep4x4
It helps if you remove the two lower screws and loosen the upper screw on the rear channel frame so that it can be pushed backwards. This will give you clearance needed to remove the window run.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-08-2009, 07:11 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Thanks for the replies. Do I need any kind of glue or anything?
I'm thinking I might as well replace my window regulators while I'm at it, how are the repops?
Beat it to fit,
Old 05-08-2009, 07:16 PM   #5
leddzepp
Moderator
leddzepp's Avatar
That is the easiest weatherstripping to replace. It pops right in, no glue needed. All you need to do is remove your door panel. I also had the triangle windows removed at the same time, so the glass slid forward and made it easier to remove the channel run. Should only take you a few mins, even where the difficult part is, as described by Leon above.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-08-2009, 10:13 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The run at the back of the wing window(vent window) is the hardest part.My pop rivet gun would not get down into the channel far enough so I cut a spacer with a tubing cutter.Made it from steel tube.They told you the rest of it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-09-2009, 12:37 AM   #7
dan42
dan42's Avatar
If you're gonna do it, I would go for it all the way and take the window and wind wing out, and replace the seal on the base of the door as well. I doing all that stuff right now to both doors and it's a lot easier and you can do a better job when it's all apart. I would look at replacing the door latch and pull assembly at the same time - mine were trashed when I took them out, and it's a 10 minute install.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-09-2009, 09:47 AM   #8
leddzepp
Moderator
leddzepp's Avatar
I used a pop rivet gun to secure the vertical seal. I had to grind it (the gun) down on both sides to get it to squeeze into the back of the channel. On a couple of them, I just flipped the gun around and riveted them from the front.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-09-2009, 09:54 AM   #9
Sinister
Between Trucks...
Sinister's Avatar
So the run at the back of the vent window needs to be riveted? Hadn't planned on replacing them but might go ahead and get it over with.
Beat it to fit,
Old 05-09-2009, 10:20 AM   #10
leddzepp
Moderator
leddzepp's Avatar
I did not rivet the felt on the back of the channel. I riveted the vertical seal on the front, and the felt just pushed in on the backside over the rivet heads. I used a little glue to set them in place.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
