Old 05-08-2009, 07:19 PM   #1
3r!c84
Badass
3r!c84's Avatar
10 bolt?
10 bolt axle diagram? any one got one?
i need to change the bearing and seal.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-09-2009, 09:00 AM   #2
LONGHAIR
Re: 10 bolt?
Diagram, no, but it is not hard at all.
Jack it up and put good jack stands under it.
Remove the rear cover.
While it is draining, remove the wheels (you might as well do both sides while you are in there).
Remove the brake drums.
Remove the center pin from the differential (carrier)
Push the axles inward and remove the C-clips. Pull the axles out.
Un-bolt the brake backing plates and set aside w/o disconnecting the brake lines. You will probably have to bend open the clips the hold the lines to the axle housing to be able to move them.
You are now down to the seal and bearing.
There is a special tool to pull the seal out but nearly any kind of prying implement will do.
The bearing is a little harder to get out. A slide hammer and a special attachment for pulling bearings is the way to go with that.
The reverse of this all gets it back together.....check the bearing surface of the axle itself before you put it back in. A worn axle will damage the new bearings pretty quickly.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-09-2009, 09:42 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: 10 bolt?
got it all apart,the seals where ez to pull out but the bearing where a pain.. tryed a slide hammer and other things.when over my nabors and asked him.he allways has to cut them out.
tryed that ,,it worked..
allso he said he is going to put some lower gears in it.he said my truck has like a 2.90 somthing?idk he is putting a 3.83 set in it..it should help some?
-00 Saturn 5spd
1/4:13:90
Old 05-09-2009, 09:46 PM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: 10 bolt?
A 3.73 would be lower which would make it a little more responsive out of the hole.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 05-10-2009, 04:16 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: 10 bolt?
yea 373 im just waiting for him to put it in.
-00 Saturn 5spd
1/4:13:90
