05-08-2009, 09:16 PM | #1 |
Tranny Whine?
if you watch my video there is a whine of what i think is the transmission. it only really happens when im in third gear feathering the throttle. is this a bad noise?
it can be heard at around :50- 1:00
1972 longbed- 454 1967 shortbed- 355 Last edited by ZombieWeinerDog; 05-08-2009 at 09:19 PM. |
05-08-2009, 09:27 PM | #2 |
Re: Tranny Whine?
I'd say rearend,and I see from your video that didn't get that radio put in yet. What happened?
05-08-2009, 09:30 PM | #3 |
Re: Tranny Whine?
well i found a new aftermarket one that was in an el comino, waiting for that to be taken out, and im still test fitting some speakers i have
1972 longbed- 454 1967 shortbed- 355 |
05-08-2009, 09:40 PM | #4 |
Re: Tranny Whine?
any idea what is making it do this?
05-08-2009, 10:36 PM | #5 |
Re: Tranny Whine?
anybody?
05-09-2009, 08:34 AM | #6 |
Re: Tranny Whine?
It sounds like the rear end. Raise the rear of the truck. With the trans in neutral grab the pinion yoke. It will have a little turning free play but must not have any back & forth looseness. Pull the cover & do the same with the carrier assem. It to will have a little rotation freeplay but must not have any side play. If they do you have some worn bearings & need an o-haul.
05-09-2009, 01:21 PM | #7 |
dazed and confused
Re: Tranny Whine?
it does sound like the rearend doesent sound to bad i have heard worse
members met: redbaron69, billsbowtie,nc67 |
05-09-2009, 10:59 PM | #8 |
Re: Tranny Whine?
Time to check the diff oil level before you drive it again.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
05-10-2009, 12:42 AM | #9 |
Re: Tranny Whine?
good plan
05-10-2009, 02:09 PM | #10 |
Active Member
Re: Tranny Whine?
Probably worn gears. An oldtimer told me Gears whine, teeth click and bearings roar. Since it only happens in 3rd I would say 3rd gears are worn. I've heard worse and yours doesn't sound that bad and other than annoying noise should last many more miles. Best way to check where it is coming from put rear on jack stands put it in gear and listen with a heater hose shoved on a piece of pvc pipe so you don't have to crawl under the truck.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
05-10-2009, 05:15 PM | #11 |
Re: Tranny Whine?
I'd check the rear end & trans. grease before I ever drove it.
