05-08-2009, 10:27 PM | #1 |
Need help with converting instr panel w/out gauges
I have a 1972 chevy pickup and I am trying go from an instrument panel w/out gauges to one with gauges. But there is an issue, I noticed that my connection to the printed circuit is only 11 pins and the panel with the gauges have a 12 pin circuit. Also the two circuits run differently to different parts of the instruments. Is there a conversion I need to get to make it a 12 pin or what? Please help with any suggestions? Thanks!
05-09-2009, 12:52 AM | #2 |
Re: Need help with converting instr panel w/out gauges
You will probably have to get an underdash wiring harness -most of the suppliers have them.
http://musclerodzstore.com/index.asp...ROD&ProdID=287 Look in the parts section - there are used wiring harnesses for sale as well, but unless you're good with troubleshooting, I would buy a new one.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
05-09-2009, 02:03 AM | #3 |
under dash harness is different, and so is the engine harness up front.
Mike Redpath |
05-09-2009, 06:16 AM | #4 |
It's alsways something.....
Kingnothin: You need one donor pin from another harness. I am doing this same thing now and figured that out also. I had a junk underdash harness that I just salvaged an extra pin from the dash plug. I can send you one if youd like, but you may find one closer-LMK
I am assuming that you are using GMC pauls how to on this (Rearrange wires from a idiot light harness to an instrument dash harness)- The link is on the FAQ page on this forum. If you need help, post here and I can assist HTH< Chuck Last edited by chuckmc8; 05-09-2009 at 06:19 AM. |
05-09-2009, 11:37 AM | #5 | |
