Old 05-09-2009, 10:30 AM   #1
mjensen
mjensen's Avatar
Cab glass removal
Well, the cab is getting close to coming off. I'm wondering about the windsheild and back glass (solid). How easy are these peices to remove and does it require the special tool to remove them? If I wanted to ensure that the glass doesn't get broken, should I just pay a company to come take them out?
On the windsheild, the passenger corner is fogged up and I'm wondering if this can be polished out or if I'm going to need to buy a new windshield anyway.
TIA
Mike
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 05-09-2009, 10:40 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Cab glass removal
the fog is bad. the film between the 2 layers of glass is going bad and there is no way to fix it.
as for removal I would plan on replacing the rubber as it is probably shrunk and needs replacement anyway. that way glass removal is easy, just use a sharp utility knife.
68C15 is offline   Reply With Quote
Old 05-09-2009, 10:58 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
The fogging is actually the plastic membrane between the two layers is the part that fogs from age/sun. You can't polish it out. You will have to replace the whole thing.
As for getting out the glass, if (and recommended) you are replacing the seals, cut the seal from the inside and push out. Have a helper.
As for putting them back in, the rear is not too hard using the rope method. As for the front, based on how many problem even pros have had with cracking, you might want to hire them and buy the glass from them. Then they are responsible if they break it during installation.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-09-2009, 01:07 PM   #4
mjensen
mjensen's Avatar
Okay, add one more item to the budget
Mike
Old 05-09-2009, 01:16 PM   #5
mbgmike
Yeah just cut out. Buy a good quality seal to. Not the crap Counterparts sell and alot of vendors. One starts with a Large L. They sell crap thats is too hard to install. Find someone who sells Precision Brand and save some time and money.I can give you all the returned rubbers we used to sell before we sold Precision for free
mbgmike is offline   Reply With Quote
Old 05-09-2009, 06:15 PM   #6
ajcan
ajcan's Avatar
Is the back window molding still available from Chevrolet?
I got my sliding window in today and need to buy the molding Monday.Where is the best place to buy for the best quality?
Thanks.
AJ
ajcan is offline   Reply With Quote
Old 05-09-2009, 06:40 PM   #7
ajcan
ajcan's Avatar
mbgmike
I work at a dealer and we have a few different glass companies that come out.
Would they carry Precision you think?
I guess I have some footwork to do.
Also,How do you get your thumbnail picture in your profile on the left?
I have it in my profile when you click on my name but not visible in the threads like many others.
AJ
Old 05-10-2009, 08:57 AM   #8
mbgmike
Originally Posted by ajcan View Post
mbgmike
AJ
I would just ask the glass guys you deal with. Thats how we found out about Precision cause they got mad at us at Binswangers glass for always bringing in crappy rubber. So we use what they use and now we sell their rubber only.
The picture is your avatar and you can down load in the user cp
Mike
Old 05-10-2009, 07:58 PM   #9
tim21391
tim21391's Avatar
windshield comes out easily.. take off the stainless. then take a box cutter and cut the rubber. then the glass should come out..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-10-2009, 07:59 PM   #10
tim21391
tim21391's Avatar
stainless just pops off...
