Old 05-09-2009, 11:57 AM   #1
cbehymer
Starter issues - Need some insight
I just put a new starter in my 68 GMC {305 V6).
When I hit the key it tries to engage the starter but it doesn't crank the engine over.
The truck sat for about a year and it was running fine before I parked it.
I can turn the engine over by hand with no problems.
I noticed that after trying to start it when I turn it over by hand I can hear the bendix releasing and clicking back into place.
I am open for any suggestions at this point.
Thanks in advance for your help.
Chris
cbehymer is offline   Reply With Quote
Old 05-09-2009, 12:31 PM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: Starter issues - Need some insight
dont know for sure on a v6 but you may have to shim/adjust it.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-09-2009, 12:52 PM   #3
cbehymer
I thought about that too but didn't see a way it could be done.
I replaced it because the old starter was doing the same thing.
I am going to start tracking the wires now.
The starter on the V6 isn't the same as the starter on small block Chevy. The mount bolts don't go up into the block. they are parallel with the starter and go through a flange plate on the end of the starter into the bell housing.
