Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-09-2009, 04:37 PM   #1
quickchevy
quickchevy's Avatar
SBC Intake Bolt ?
Going to replace my intake.I read where arp bolts are shorter than they use to make.That you should use BBC intake bolts because they are longer.SBC is 1.00 and BBC are 1.25.Its a performer eps.What do yall think.
quickchevy is offline   Reply With Quote
Old 05-09-2009, 05:42 PM   #2
cdowns
cdowns's Avatar
Re: SBC Intake Bolt ?
i never pay attention to prepacked bolt kits i always measure what i need and use the correct length bolts
Old 05-23-2009, 10:32 AM   #3
fdbdw
fdbdw's Avatar
hey quick, getting ready to install a new intake and was wondering what you ended up doing for bolts, hope it whent well
fdbdw is offline   Reply With Quote
Old 05-23-2009, 10:57 AM   #4
quickchevy
quickchevy's Avatar
Been busy and have not got around to it.I have arp bolt kit for small block chevy.
Old 05-23-2009, 08:50 PM   #5
70c10
67-72 Addict!
70c10's Avatar
I called ARP last year and was told the SBC bolts are what you need for the aftermarket intakes but I remember a board member had problems and switched to the longer BBC bolts with no problems.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-23-2009, 10:12 PM   #6
quickchevy
quickchevy's Avatar
Thanks.Thought i saw it on here at some point.
Old 05-24-2009, 11:20 AM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
Especially with aftermarket intakes and heads, you need to pay attention to the bolts that line up with a couple of the pushrods. If you use too LONG of a bolt you will make contact and bend or rub the pushrod. Especially in aftermarket heads where they have shifted the valve / rocker/pushrod placement to make bigger intake ports this can be a serious ugly. The two end bolts are blind holes (meaning they are not a 'through hole' with threads all the way through a hole) The threads will not go 100% to the bottom of the hole in that boss cast at the end of the heads. Just make sure your bolt is the right length to have plenty of thread contact, but not bottom in the hole. Your particular intake gasket material, and intake flange thickness will be different than the stock setup so like cdowns said you really need to just measure what you need for each bolt to get it 100% right.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-24-2009, 05:19 PM   #8
quickchevy
quickchevy's Avatar
Ok thanks.Its a ELD eps intake and camel back heads fel pro 1256
Old 06-09-2009, 07:45 AM   #9
fdbdw
fdbdw's Avatar
hey quikchevy
just installed my eld eps and 1406 and wanted to catch up with ya and let you now that i used 1" bolts and they were plenty long enough I have stock heads so probably some difference there, just letting ya know
