Old 05-09-2009, 06:43 PM   #1
frankyjoet
Unhappy trouble shooting elec.
Recently i installed a reman starter/solenoid combo. Have the wires attached
correctly (3) wires. When i turn the key i don't hear anything. Could this be
an ignition problem. The battery is fully charged. please advise
thanks
frankyjoeyt
frankyjoet is offline   Reply With Quote
Old 05-09-2009, 08:14 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: trouble shooting elec.
check with a multimeter your positive terminals for power...
if they both get power twhen they are supposed to then the starter is bad..
it is highly unliely you messed up anything after replacing the starter..
especially if you disconnected the battery as required...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 05-11-2009, 04:19 AM   #3
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Standard shift trans? maybe bad clutch safety switch.
Auto trans, bad neutral safety switch.
heavychevy79 is offline   Reply With Quote
Old 05-11-2009, 10:13 AM   #4
Tony@AirRideTech
Junior Member
sounds to me like you have your solenoid wire on the wrong terminal...
Tony@AirRideTech is offline   Reply With Quote
