Old 05-09-2009, 06:56 PM   #1
RShaips
Where do these wires go?
I just pulled the cover on my tranny and see these two wires hanging, where should they go? I am going to drop the tranny and transfer case, get the tranny rebuilt and clean and paint everything underneath. Transfer case was originally orange, right ? Thanks
RShaips is offline   Reply With Quote
Old 05-09-2009, 07:05 PM   #2
RShaips
Re: Where do these wires go?
Forgot these!
Old 05-09-2009, 10:27 PM   #3
jaros44sr
jaros44sr's Avatar
Good Question. I also have the same wires hanging down, with a black angled spade connector. They feed back to the firewall above the fuseblock and go thru to the inside...Any ideas guys?
I've looked at my wiring diagram with no luck
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-10-2009, 12:10 AM   #4
old man jimmy
Just a guess. But I would say they're for the back-up lights with a 4 speed. GM used to be great about wiring for either or.
old man jimmy is offline   Reply With Quote
Old 05-10-2009, 01:02 AM   #5
balloonknot
I bet they are part of some emissions stuff they tryed for a few years. some sort of spark,timing,shifting thing. I forget what they called it, when I cleaned up my blazer I got rid of that and it's relay up under the dash by the brake pedal.
balloonknot is offline   Reply With Quote
Old 05-10-2009, 08:18 AM   #6
jaros44sr
jaros44sr's Avatar
Maybe, mine was a standard shift at one time. But, that big red one has me stumped, the plastic connector was melted so it pulled some heavy amps at one time...
I'll check out that relay. I was sorta thinking electric choke, but don't know
SAFETY FIRST
AS usual, off topic
Jim
Old 05-10-2009, 11:16 AM   #7
RShaips
The end of the big red wire on mine is also melted.
