Old 05-09-2009, 07:01 PM   #1
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
factory alternator, worth holding onto?
Hey guys. I pulled my alternator to test it today and its no good. It failed twice on a tester at autozone. Just curious if I should go back and pay the core charge to get the original alternator back? Its a $10 core charge. Im not sure if it is something special to hold onto or not. U tell me? Thanks
Michael
wancosc356 is offline   Reply With Quote
Old 05-09-2009, 07:17 PM   #2
JimKshortstep4x4
Re: factory alternator, worth holding onto?
There are lots of the original low output 37 amp alternators. Unless you want to keep the numbers that match the date code of the engine they are not worth keeping.
With the age of these trucks it is possible that it was not the original alternator anyway.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-09-2009, 08:12 PM   #3
wancosc356
wancosc356's Avatar
oh ok. sounds good. Im not too worried about it. Just didn't wanna catch flack for getting rid of it. Yeah. I hear ya. Thanks.
Michael
Maybe someone can help me on a side note:
Im replacing the battery cables and the negative that runs from the block to the battery has a little smaller cable coming from the terminal connector. Can anyone tell me what that is supposed to connect to??? I know the positive cable that runs from the starter to the battery has the smaller cable connected to another cable on the inside of the fender on a mount...I assume that is correct. Anyways, any help would be appreciated. Thanks
Old 05-09-2009, 09:20 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by wancosc356 View Post
.... I know the positive cable that runs from the starter to the battery has the smaller cable connected to another cable on the inside of the fender on a mount...I assume that is correct. Anyways, any help would be appreciated. Thanks
The positive is correct and on the negative it probably is for some sort of ground. Probably a replacement cable. I didn't have it on my original 68 GMC that I remember.
68gmsee is offline   Reply With Quote
Old 05-09-2009, 10:12 PM   #5
wancosc356
wancosc356's Avatar
Yeah. Thanks. I just realized that since I am using replacement universal cable kits, that they are for negative or positive. So the one on the negative will not be used. Thanks.
