Old 05-09-2009, 09:09 PM   #1
lablue73k5
Cool 1973 blazer sits
I have a 73 chevy blazer and seats from 2006 chevy silverado dual cab, can I put them In the blazer? I'm pretty sure the two bucket seats will not be a problem but I am concerned bout the bench, what do you think can I do it?
lablue73k5 is offline   Reply With Quote
Old 05-10-2009, 12:48 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 1973 blazer sits
Welcome to the board from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-10-2009, 02:20 AM   #3
Cyclone44
Step Brother
Cyclone44's Avatar
I will move this to the place were you will get more responses.....Welcome to the site....
Cyclone44 is offline   Reply With Quote
Old 05-10-2009, 12:32 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
First thing Welcome to the site!!
And yes they will work, you will need to drill some new holes, but I think you can use 2 of the stock hole on each side. You will need to weld a small plate on the back side of the floor or put nuts on you bolts. Post some pics when you get time..
Trav
tvblazer78 is offline   Reply With Quote
Old 05-10-2009, 09:24 PM   #5
tobiahr
tobiahr's Avatar
the center seat will be a tight fit if you use the stock mounting locations on the front of the seats but it can be done with a little tweaking. as stated before you will need to drill holes for the rear mounting
tobiahr is offline   Reply With Quote
