Old 05-09-2009, 09:20 PM   #1
otsenre
otsenre's Avatar
6 lug to 5 lug axle exchange?
I have a 68 chevy 6 lug 1/2 ton coil spring and a 72 5 lug leaf springs. I want to install 72 axles on the 68. What is my easy road to go about this? The front axle I think I will just swap out, but rear concerns me because of the coil and leaf spring difference. Any info appreciated
otsenre is offline   Reply With Quote
Old 05-09-2009, 09:45 PM   #2
kgt
Re: 6 lug to 5 lug axle exchange?
I think the widths are different by a bit..??..if i remember... as are the perches of course, I redrilled my 6 bolt axles to a 5 bolt pattern on my 68.....
kgt is offline   Reply With Quote
Old 05-09-2009, 10:15 PM   #3
DMARCUM123
i just had my redrilled and the center turn down. good for a cruiser
DMARCUM123 is offline   Reply With Quote
Old 05-10-2009, 10:58 PM   #4
otsenre
otsenre's Avatar
I am not sure I am following what you mean exactly by redrilling? What is the width difference?
Old 05-10-2009, 11:24 PM   #5
weircc
weircc's Avatar
my truck is a 70 with a 12 bolt coil spring i found a mid 70's Chevy truck with a 12 bolt and swapped axles didn't change housing was very simple cost me about 50$ hopefully you can go this route just make sure the axles are same length
weircc is offline   Reply With Quote
Old 05-10-2009, 11:33 PM   #6
westofb
I really hate wet sanding!
westofb's Avatar
I am thinking I read this too, that the 71-2 housings/ axles are different in width length than the 67-70. I you could cut the perches off and swap them around. I know they sell a kit that comes with perches but not cheap, around $130 if I remember right. Find someone with a hollander interchange manual...might help you find axles you need to do what weircc did.
westofb is offline   Reply With Quote
Old 05-11-2009, 12:07 AM   #7
HuggerCST
HuggerCST's Avatar
The 72 axles & drums will bolt into the 68 housing, but each axle will be 3/4" longer than the '68 axles, so unless you put a spacer behind each brake backing plate, your brake shoes won't be all the way in the drums.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-11-2009, 09:31 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here are the perches if you want to swap the whole thing
http://www.stockcarproducts.com/trkarm1.htm
If you find a 70 you can just swap out the inner shafts, but like mentioned the earlier pre 70's are a 1 1/2 narrower.
sneakysnake is offline   Reply With Quote
