05-09-2009, 09:21 PM | #1 |
Installing front cab support on 64 pickup
I'm replacing the rusted out cab supports, floor, and rockers on my '64 pickup. When test-fitting the front cab support, I found that there is about a 1/2" gap between the "ears" and the floor support. Also, it doesn't mount at exactly 90 degrees. I braced the door jamb before taking it apart, and I remounted the door to confirm that it still fits OK, so I don't think the cab has shifted while I've been working on it. However, who knows if it was really square before I started?
If anyone else has encountered this problem, I'd like to hear what you did about it. How can I weld the cab support to the floor support? Should I fill the space with a piece of thick steel, or do you have any other suggestions? |
05-09-2009, 09:28 PM | #2 |
Junior Member
Re: Installing front cab support on 64 pickup
I sure did on my 66 and Alan did on his 65 project. We both bent our ears out straight and then just butt welded the pieces. I think there are some pics of it i Alans Classic build on this site.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
05-09-2009, 09:36 PM | #3 |
Hi Bob,
Thanks for the quick reply. Did yours mount up square, or was it also off a little? |
05-10-2009, 09:57 PM | #4 |
Junior Member
I think the main part will be that it lines up square at the other end where it bolts up to the A pillar. I had taken mine off....Alan left his on for a reference. If the A pillar is still there, line it up with it and just weld the rest in where it fits.
05-11-2009, 12:09 AM | #5 |
Thanks, I really appreciate the input.
05-11-2009, 10:17 AM | #6 |
Junior Member
That means you may either have to weld the hole shut on the inboard end and re-drill it, or cut a slot so the bolt will fit thru.
05-11-2009, 05:22 PM | #7 |
Don't you just love these "Quality Reproduction Parts"?
05-12-2009, 12:19 AM | #8 |
60-66 Nut
It's really too bad someone doesn't make "good" patch panels for these trucks. I myself would gladly pay more $$ if the fit like they should.
