Old 05-10-2009, 11:14 PM   #1
weircc
weircc's Avatar
Have a question about parking light 67-68
Ok so here is my problem i am putting my truck back together with new painless wiring when i started doing the headlight section i notice there is a turn signal and parking light wire, so im thinking no big deal both of them go to parking light. But then i realize that one is a ground and since how there is only two wires coming from parking light does this mean that on the 67 that there was no parking light just a blinker only?
weircc is offline   Reply With Quote
Old 05-11-2009, 12:04 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Have a question about parking light 67-68
the light grounds through the housing into the grill assembly, you'll find everything grounds through the body and pretty much nothing on the truck has a ground ire.
Old 05-11-2009, 08:22 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
If it'll help ya....I can get you a pic of my wiring tonight....I have a 68 and used the painless wiring system...let me know....Thanks
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-11-2009, 08:41 AM   #4
68gmsee
Active Member
68gmsee's Avatar
One more thing. Being as these trucks have set for 40 years and mounting bolts have rusted or are dirty and some frames painted, it would be wise to install some ground straps to complete a good solid return to the battery.
I know from experience that weird things happen to the rear lights without a good ground.
68gmsee is offline   Reply With Quote
Old 05-11-2009, 06:28 PM   #5
weircc
weircc's Avatar
every single thing on this truck is brand new i haven't even wired the lights yet that's where i stopped and some pics would be great thanks. that's what got me the one wire was black so i assumed it was a ground instead of one being blinker and one being parking
Old 05-11-2009, 07:18 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Okay weircc,
here's a couple pics of the driver side headlight, parklight/blinker, and side maker (not sure if you are running one??)...Let me know if you need anymore...it's just a short walk back out to the garage....for the plug that goes through the rad. support, I cut and stored the brown wire and connected the 926 t the purple and the 927 to the blue....(see pic)
By the way, a couple things to keep in mind while doing it that I learned....plan out where you want to put the "maxi-fuse" (someplace easy to reach, but hidden if you are looking for the clean look), also, I had to install a diode inline with the alternator because the engine wouldn't shut down when the ignition was switched off (depends on the alt you run)...should be in the directions...Oh...FYI....when you turn on the headlights, the parklights will go out and only blink when the blinker is engaged....hope this helps some!!!....
Geoff with a G
Old 05-11-2009, 07:30 PM   #7
weircc
weircc's Avatar
ok im seeing some light on the situation but i dont have the old harness because my truck is a 70 and i converted to 67 i have no side markers. i see three wires on your parking lamps and mine only has two i will post some pictures later tonight
Old 05-11-2009, 10:31 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
I found some parklight plugs in the junkyard because my old harness was junk in some places....If you can find a donor harness it would be helpful because you'll need the connectors or you'll end up at the parts store looking for connectors....
No side makers is no problem....just post up pics with questions...I know if I can't help there are lots of others that know this better than my rookie self!!!LOL
Geoff with a G
Old 05-12-2009, 01:34 PM   #9
weircc
weircc's Avatar
here is what im working with that why im confused
Old 05-12-2009, 05:26 PM   #10
michael bustamante
michael bustamante's Avatar
purple is your poitive/turn signal I believe. like the other guys were saying with the origional 67 headlight switch the parklights go off when the headlights are turned on and act as signals only 69 and up didnt do this. I read that if you splice the purple wire into the brown that it stays on as a parklight. so with the painless kit, both your turn signal and the parklight should tie into the purple wire. I`ll have to look on the 62 i used this kit on to make sure and Ill let you know.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-12-2009, 07:25 PM   #11
Longhorn Man
67 is the only year for no parking lamp when headlights are on.
Off the top of my head, the purple is parking light, and the dark blue one one sside and light blue on the other side would be for the flasher. It grounds through the assembly, no third wire needed per stock harness.
Off topic, those selft tappers should be removed and replaced with nuts and bolts. They'll end up vibrating loose.
Old 05-12-2009, 07:35 PM   #12
weircc
weircc's Avatar
they only have a purple and black same on both sides
Old 05-12-2009, 08:33 PM   #13
Longhorn Man
yeah, bummer they don't use normal GM colors for things huh?
Old 05-12-2009, 09:12 PM   #14
72Subby
72Subby's Avatar
(kinda related)
I think it's in the Ron Francis catalog (awesome catalog full of good information) there is a diagram of the 1157 (?) bulb and it explains which filament is the brake and which is the tail (one is brighter) light.
I'm thousands of miles from my truck, garage or tools, just living vicariously through the net, so this tidbit is from memory but I remember seeing that diagram and thinking, "oh, that's gonna help me later when I wire this truck..."
Help! My project parts hauler became a project!
72Subby is offline   Reply With Quote
Old 05-12-2009, 10:01 PM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
Do you have the female connector that'll plug onto the one you have in the rad support??....Sounds like from the above you have purple and black from the parklight to the rad support too....I say try connecting the purple to the 926 (brown) and the black to the 927 (light blue)...leave a little extra wire if you need to re-splice for some reason...trial and error i guess??!?!...let us know how it works out!
Oh...here's a wiring diagram I pulled from the FAQ thread (see my signature area for a link)....maybe it'll help?!?!?
http://www.geocities.com/chevroletc1070/v8engcomp.html
Geoff with a G
Old 05-12-2009, 10:33 PM   #16
weircc
weircc's Avatar
thats what im working on is the female connector when i get that i will start working on it again
Old 05-13-2009, 09:51 AM   #17
michael bustamante
this is how the 62 chevy I wired using the ez wire kit is wired and works fine, I was wrong in the first post. the black wire is NOT a ground.
1967custom
Old 07-04-2009, 03:45 PM   #18
howard_m18
howard_m18's Avatar
New at this as my 67 sat in the garage for 10 yrs & it is now time to "get it done." What is a wireless /painless wire kit? Howard
howard_m18 is offline   Reply With Quote
Old 07-04-2009, 05:52 PM   #19
weircc
weircc's Avatar
its just a new wiring harness for our trucks but wouldn't recommend get an American autowire
Old 07-04-2009, 10:09 PM   #20
Longhorn Man
an aftermarket replacement... not a direct replacement OE style.
