05-11-2009, 12:46 AM | #1 |
Intake mounting alignment
anyone here use one of these vortec intakes?
The reason I'm asking is because, I can't seem to get the mounting hole to line up, take a look. FRONT PASSENGER SIDE AFTER GETTING THE DRIVER'S SIDE LINED UP BACK PASSENGER SIDE AFTER GETTING THE DRIVER'S SIDE LINED UP EVEN THE 1" MOUNTING BOLTS ARE TO SHORT I'm just going to return it and get an Edelbrock. I sure hope its the intake and not my engine. I am using the Patriot Cast Iron Vortec Heads, I sure hope they are ok,fitment wise.
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
05-11-2009, 06:51 AM | #2 |
and a few others
Re: Intake mounting alignment
Interesting. I'd like to know the answer too.
Let's see if we can get this moved to "engine & drivetrain"
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
05-11-2009, 07:08 AM | #3 |
sharp as a marble
I have installed a couple of these and had a similar problem. My problem was, like you I could not get the bolts started with a washer behind them. I would return it, and ask for another one. The ones I had problems with were not vortec, but were the same brand. after the second one, I quit usuing them , and went back to Edelbrock. I think the one you have is made offshore.
05-11-2009, 07:20 AM | #4 |
blood type; Retumbo
the bolts will not line up without the correct gasket in place. it will take a Fel-Pro 901312 IIRC. they are thick plastic and have a rubber bead around the openings. felpro also has a super high quality set with a stainless steel frame but those only come in a full set (upper and lower along with all other required stuff for intake replacement). look them up for a '98 K1500 with a 5.7 VIN "R".
05-11-2009, 07:27 AM | #5 |
blood type; Retumbo
you also need to get the bolts for said application and follow the torque sequence AND SPECS very closely. use blue thread locker. I could measure some spare bolts at work today if you want to hit the hardware store. IIRC the torque specs are; first pass= 40 in/lbs, second pas=80 in/lbs, third pass=137 in/lbs (11 ft/lbs), and finally go back over to make sure all are at 11 ft/lbs.
05-11-2009, 07:27 PM | #6 | |
Thank You.
05-11-2009, 07:36 PM | #7 | ||
I think I will cut my losses and get an edelbrock. I was just in a hurry when I bought this intake anyways, and really wanted the RPM AIRGAP so I guess this will just nudge me in that direction. Thanks for the help everyone. Just one more reason why I feel guilty I haven't sent in my $25.00 yet. Maybe after I get the truck running I will come to my senses...
05-11-2009, 11:14 PM | #8 | |
60-66 Nut
05-12-2009, 04:02 PM | #9 | |
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
