Old 05-11-2009, 06:29 AM   #1
rockdawg
Drum Brake Repair Question
I need to replace a leaking wheel cylinder on the front of a 69 with drums. I need to remove the large nut on the top (@ 12 o'clock) that holds the springs and wheel cylinder. This thing has not seen daylight in 40 years and does not want to budge. I just want to double check that this thing does have right handed threads doesn't it? I do not want to tear anything else up trying to get it loose. Any tips on getting this thing off other than a breaker bar and cheater pipe?
'69 Chevy CST
383 Stroker
TH400
rockdawg is offline   Reply With Quote
Old 05-11-2009, 06:45 AM   #2
cdowns
cdowns's Avatar
Re: Drum Brake Repair Question
wheel cylinders are held in place by 2 small bolts if i remember the fronts correctly
Old 05-11-2009, 06:48 AM   #3
cparman
sharp as a marble
The large nut is right hand threads. I would suggest trying to get access to a air powered impact. With an air gun, you might vibrate the nut loose much easier than using a socket and a pull handle. If air is not an option, try making the handle longer on the pull handle, by slipping a pipe over the end.
cparman is offline   Reply With Quote
Old 05-11-2009, 06:50 AM   #4
jim zag
ENGINE BUILDER
jim zag's Avatar
I had the same problem and the wheel cylinders were pitted from rust. I would replace both fronts and probably the rears too!
JIM ZAG
jim zag is offline   Reply With Quote
Old 05-11-2009, 07:38 AM   #5
rockdawg
Thanks for the info guys. Yes, I am replacing both front wheel cylinders with new ones.
'69 Chevy CST
383 Stroker
TH400
Old 05-11-2009, 08:56 AM   #6
68gmsee
Active Member
68gmsee's Avatar
On two wheel drives, I agree with cdowns. rockdawg, which big nut are you referring to?
Since you sign rockdawg I'm assuming this is a 4 wheel drive truck. I'm not familiar with these...
68gmsee is offline   Reply With Quote
Old 05-11-2009, 10:54 AM   #7
Elephanthead
Must be a 4x4 thing, mine had 2 little bolts.
Elephanthead is offline   Reply With Quote
Old 05-11-2009, 11:30 AM   #8
Brad
Out of the carpool lane.
Brad's Avatar
I think the 2wd's had the nut, but maybe I had a 4wd front hub??? I just did this to my '67 several months ago and had the same problem- the nut was a pita to get off!
Yes, the nut is standard threads-right hand threads. I'd get an impact socket as I ended up breaking a standard socket when I did it. I needed a breaker bar as well.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 05-11-2009, 11:34 AM   #9
rockdawg
It's a two wheel drive. I have seen online where the are two different types of wheel cylinders on these trucks. I believe due to two different widths of brake shoes. Mine is held on with the one large bolt/pin that the springs clip on to. I will try and post a pic tonight.
'69 Chevy CST
383 Stroker
TH400
Old 05-11-2009, 11:41 AM   #10
chuckmc8
It's alsways something.....
chuckmc8's Avatar
If you cant get it off, just replace the rubber cups in the wheel cylinder. They are available at any parts store. Youll need to hone out the cylinder first, but the hones fit in a drill motor and are available at the parts store also.
chuckmc8 is offline   Reply With Quote
