Old 05-11-2009, 08:27 AM   #1
dznucks
dznucks's Avatar
Need Pic of cross member
I am looking for a picture of a 3-speed transmission crossmember for a '69 c-10 SWB. My truck has never had one but it appears that all the mounting holes are there. Is it possible to fabricate your own?
dznucks is offline   Reply With Quote
Old 05-11-2009, 09:02 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Need Pic of cross member
Here's half a pic.LOL Manuals have a cross member that supports the bell housing, nothing under the trans itself. They have to be cut out when going with an automatic because they get in the way.
sneakysnake is offline   Reply With Quote
Old 05-11-2009, 09:42 AM   #3
Griffin
I'm about to pull one out of a 1967 1/2 ton. I think they're the same. You can have it if you want to pay the shipping. Send me a PM in about 2-3 weeks (if you can wait) and i should be at that point.
Griffin is offline   Reply With Quote
Old 05-11-2009, 10:21 AM   #4
dznucks
dznucks's Avatar
Thanks for the pic. That is a bellhousing cross member. i think they refer to it as the rear engine mounts. I am looking for the cross member that goes behind that one, the tranny tail shaft mounts to it.
Griffin, are you talking about the bell housing member or the tranny cross member? can you get a pic?
Old 05-11-2009, 11:07 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's all there is. On pre 73 standard trans trucks, the bellhousing crossmember is it. The trans simply hangs off the bellhousing without a rear crossmember. I'm serious.
Old 05-11-2009, 11:23 AM   #6
lchall
Here's a couple of pics from mine during demo. I had a 3-speed in a 72, but I think it should be the same for you. Like Tx_Firefighter said it bolts to the bellhousing instead of the transmission.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 05-11-2009, 01:15 PM   #7
dznucks
dznucks's Avatar
OK. I have always wandered if mine was removed by a previous owner. it looks like one could easily be fabricated and bolted in.
I know there is a tranny mount called out at autozone, orielly's and napa. but no bell housing mounts.
Old 05-11-2009, 05:09 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The tranny mounts were like you are thinking for the Automatic.This may be what you are finding at the AP store.IIRC there are some small rubber mounts on the bellhousing style also(between the BH and crossmember).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-11-2009, 07:53 PM   #9
greg65
greg65's Avatar
If things don't work out with Griffin let me know. I've got one out of a '68 parts truck. It still has the bellhousing attached.
greg65 is offline   Reply With Quote
Old 05-12-2009, 11:39 AM   #10
Griffin
I have the bellhousing mount. They didn't have a rear mount. The tranny should have the "boss" on the tailshaft for a 2 bolt chevy trans mount. You're right, you can make one out of square tubing or if you need the one i got that's cool too. Let me know.
Old 05-12-2009, 11:55 AM   #11
Skirkpat
Skirkpat's Avatar
You can use the automatic crossmember, and drill holes in your trans, tailshaft if I am not mistaken ?
Skirkpat is offline   Reply With Quote
Old 05-12-2009, 02:49 PM   #12
dznucks
dznucks's Avatar
If there is not supposed to be one, i may not put one in.
I just replaced the motor and bellhousing mounts and i still have a wierd vibration that feels like the transmissions is loose.
thanks
Old 05-12-2009, 06:48 PM   #13
PanelDeland
IIRC there is some reason for not using the tranny mount and the bellhousing mount(Maybe stress on the tranny with both?).If the issue is a vibration check the carrier bearing.It is in the middle of the 2 piece driveshaft.
