05-11-2009, 10:42 AM | #1 |
Fuel gauge problem
The 80 Scottsdale that I picked up a few weeks back, I have been going thru and fixing some of the little problems and I have one I need some input on.
It was on fumes when I picked it up, needle was below E. First stop was to the gas station. Put 10 gallons of gas in it and the needle just jumps all over the place. My first thought was the sending unit in the tank, but it does it when the truck is moving or just sitting. The truck doesn't even have to be running, you can just turn the key to the on position and it starts to move around. Could it still be a sending unit issue? Possibly the gauge in the dash or a ground issue? Will hopefully have pics up by this weekend, had to buy a new camera.
Keith ------------- 1980 C-10 1981 C-30 |
05-11-2009, 10:53 AM | #2 |
Junior Member
Re: Fuel gauge problem
sounds like the resistor in the guage itself..... easy item to replace.
05-11-2009, 11:34 AM | #3 |
praise the lowered
hmmm... Interesting. I have a fuel gauge problem as well. My fuel gauge only registers half a tank when it is full. It will never register a full tank, on either side I switch it too. It doesn't move around though it is stable.
Tony, what is this resistor you speak of?
If you get bored... a) Check out additional photos of my truck in my profile 2) www.myspace.com/turnvail (music I make). I know it's weird last) contact me I will teach you to fly. |
05-11-2009, 04:43 PM | #4 |
Could be the sending unit...mine was doing the same thing but then after I couldn't get ahold of a fuel tank without pinholes rusted in it, I ordered a new fuel tank from RockAuto. While I was at it, I went ahead and got the sending unit with it too.
Fuel Tank $78.79 Fuel Tank Sending Unit $46.79 Installed both and no issues from fuel gauge after that. Matter of fact, it's dead-on accurate. I ran my truck (20 gallon tank) to 1/4 tank according to the gauge, and when I filled up, could only get 15 gallons in. |
05-11-2009, 07:38 PM | #5 |
The gas gauge in my 75 C-10 has an 82-ohm ceramic resistor bolted across two bolts on the backside. Wonder if this resistor has a different value on different models?
There are three pins (bolts) located at 9 o’clock, 3 o’clock, and 6 o’clock on the backside of the gauge. With the 82-ohm resistor in place the resistance of the gauge reads. 9 pin to 3 pin = 42 ohms 3 pin to 6 pin = 145 ohms 6 pin to 9 pin =104 ohms Resistance with the resistor removed reads. 9 pin to 3 pin = 85 ohms 3 pin to 6 pin = 188 ohms 6 pin to 9 pin =104 ohms
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. Last edited by ron350; 05-11-2009 at 07:40 PM. |
05-11-2009, 09:04 PM | #6 |
praise the lowered
Tantrix, are you referring to my issue or wydomkr? Or Both?
05-12-2009, 07:31 AM | #7 | |
Sorry, I was referring to wydomkr. I'm assuming you have 2 tanks on yours since you said: Quote:
05-12-2009, 09:03 PM | #8 |
praise the lowered
Yeah that's true. Thanks for the advice!
05-13-2009, 10:19 AM | #9 |
Thanks for the advise and suggestions, I bought another gauge cluster, so I guess I'll try the dash gauge first and see what that does and then move on the the tank sender.
10-27-2009, 12:07 AM | #10 |
Sorry to kind of bring up an old one, Having problems with my fuel guage, it reads way past Full all the time and when I shut if off it goes back to E, if I just turn the key on it runs right back up to way past full.....any thoughts?
77 Scottsdale,.454 .30 over, 10:1 flat top pistons, 480 lift comp cam, 781 heads stock valve size, some no name polished aluminumn dual plane intake advised by my machine shop to match the cam(He said is was great lol) Holley 750 vac sec, Turbo 400 built raybestos clutches and Kolene steels, Eaton Posi 3:73 14 bolt |
