Old 05-11-2009, 12:01 PM   #1
buzzback
Smile buzzback
I just bought a 1985 GMC Sierra Classic, 4 speed manual, 4x4, 3/4 ton pickup, with a 350 engine; it looks good, runs great and the price was right. I know zip about 1980s GMCs so I need some help.
Does anyone know how I can determine tow capacity and also how to determine gear ratio of the differential. Former owner said it was a "heavy duty 3/4ton" (which means what?). He also mentioned that it was a HD engine with a cast steel crank; would this have been factory installed and how do you tell?. Thanks
buzzback is offline   Reply With Quote
Old 05-11-2009, 11:45 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: buzzback
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-12-2009, 03:46 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Re: buzzback
The gear ratio can be determined by the cast # on the housing, or by the VIN I believe.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=9
then...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=10
followed by...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=11
which leads us to...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=12
which should explain everything, I hope...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-12-2009, 05:56 AM   #4
D13
D13's Avatar
Re: buzzback
First stop, the parts label. usually in the glove box, or on one of the inner fenders. It will have the option codes that the truck was built with. Be aware that many parts may have been swapped over the years.
For the axles, if all else fails (I have never been able to read a code after MI corrosion was done) - use the LMC catalog to tell you which type of axle you have, get a cover gasket and lube, then upen her up, clean it out (probably needs it anyways, I think I'm the only guy who maintains his rear LOL!), then count the teeth on the ring gear and the pinion gear. The ratio is what gear you have.
For the engine, it's most likely just another 350. But there is a code on a pad on the front of the block, just below the cylinder head, that can be checked at Mortec to ID the engine. Don't have the link handy, but look over in Engines.
There's a towing capacity thread a couple posts down. Makes it pretty clear what's what.
Love them GMC's! Enjoy!
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-17-2009, 11:39 AM   #5
buzzback
Smile Re: buzzback
Thanks Gents for the help. You pointed me in the right direction and I learned what I wanted to know.
Old 05-17-2009, 11:54 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: buzzback
That what this place is all about...
Articles-
"Refining Sierra"
Old 05-17-2009, 11:54 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: buzzback
welcome to the board... so how about some pics of this truck?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
