Old 05-11-2009, 08:32 PM   #1
smoked68
smoked68's Avatar
4 speed to 5 or 6??
How much trouble is involved in replacing my 4 spd. Muncie with a Tremec 5 or 6 spd.? I know the Summit 5's will handle up to 600 lb ft of torq. So what all will I need?? Thanks, Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 05-11-2009, 08:42 PM   #2
Jim_PA
Re: 4 speed to 5 or 6??
Tremec's use the fine spline clutch disc. I think you need a yoke, and some crossmember work... maybe more. Wish I was doing the same thing!
Jim_PA is offline   Reply With Quote
Old 05-11-2009, 09:58 PM   #3
smoked68
smoked68's Avatar
Getting ready to build a 383 to around 400 hp, then run more boost on the SC. I need a trans to handle some torq. Do the Tremec's need the use of a slave cylinder or will they hook up like my Muncie??
Old 05-11-2009, 10:58 PM   #4
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
i would recommend going to www.classicchevy5speed.com orhttp://www.keislerauto.com/
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 05-11-2009, 11:00 PM   #5
Jim_PA
Nope, with a Tremec, you can use your same bellhousing and clutch (provided it's a fine spline...)
Old 05-12-2009, 11:29 AM   #6
Willy Prost
Tremec TKO has been in the truck for several years now. Here are some thread links.
http://67-72chevytrucks.com/vboard/s...01#post2657501
Willy Prost is offline   Reply With Quote
Old 05-12-2009, 03:23 PM   #7
smoked68
smoked68's Avatar
Thanks so much guys, thats what I was looking for.
Old 05-12-2009, 07:36 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
I have a TKO 500 in my 69, with a BBC. I used a Muncie bellhousing, Centerforce clutch and hydraulic throwout bearing - had a turbo 400 before. your muncie to tremec swap will be a piece of cake. I used www.standardtransmission.com and they were awesome. Their tech/sales department knows their stuff and are great to work with. I tried calling keisler, D&D, and some other of the people that sell their tremec 'kits'. No one even came close to the service I got from the guys at standard transmission.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
