Old 05-11-2009, 10:45 PM   #1
MN Rooky
1971 4X4
MN Rooky's Avatar
Hard Brake Pedal
Trying to trouble shoot my brake problem. I just replaced the rear end and put on a new master cylinder. I bled the brakes and I still don't have good brakes. The pedal is hard. You can push like hell and the brakes will stop you. I'm thinking I have to take off the booster and get it checked some where. Is there anything that I have over looked?? How do you know if the booster is bad? Is there other year trucks that I can swap it out with. My truck is 1971 3/4 ton 4x4.
MN ROOKY
1971 Chevy 3/4 4X4, 4" lift, 33's
2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck)
MN Rooky is offline   Reply With Quote
Old 05-11-2009, 10:48 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Hard Brake Pedal
Sounds like your booster is bad. check your vacuum line and make sure it's working.
Next step on the pedal and start your truck.....if it drops your pedal it good, if not it's BUTTCO.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
