05-12-2009, 12:37 AM | #1 |
Weatherstripping advice needed
Anybody have some good weatherstripping application advice? Got my truck back from the paint shop some time ago, and though it's just been sitting, about half the new door weatherstripping has come off. What's the best way to re-prep the area, adhesive to use, application method? Thanks for the help - I really appreciate this web site!
05-12-2009, 01:27 AM | #2 |
Re: Weatherstripping advice needed
I got some advice from someone here and it works perfect. Junkyard, look for mid 90's Chevy trucks and get the stripping ouuta there. I did and works and looks great. These have the metal strip inside so you need no glue. Just fit, cut excess off at the bottom and then cruise.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
05-12-2009, 08:40 AM | #3 |
Active Member
Use 3m adhesive remover
followed by total prep wax and sillicon remover followed by 3M8008 weather strip adhesive Make sure to use the 8008 - 3M has several products out on the market and this one is normally used by the body shops and kept in the commercial area at Auto Zone - you need to ask for it
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
05-12-2009, 09:51 AM | #4 |
Between Trucks...
I'm using the press on type of seal from GMC Paul's. Took a while to break in, but they seal real well and are easy to install.
Beat it to fit, Paint it to match... |
05-13-2009, 02:04 AM | #5 |
Thanks for the replies, guys. Wish I'd known about the non-glue options before I started all this - sounds simpler and easier. Since I have the new rubber already, I'll try the strip/reglue and see how it goes.
