05-12-2009, 03:14 AM | #1 |
what do i need
so usually i wouldn't be asking a silly question like this but i want to make sure i have every tool i need to pull a front end a rear end booster and box from a truck this week seeing as I have to drive 2 hours one way to get to it. so any help would be great. also any problems any of you have ran into while pulling the front end that you could give me tips on would be great. I can pack my yukon full of stuff i just want to make sure it all goes smooth. thanks guys
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
05-12-2009, 04:57 AM | #2 |
UCA63
Re: what do i need
If you have power take you air comp,impact gun and a die grinder w/zip cutter
No power ? I'm thinkin' cutting torch Side cutters (for brake lines etc) A pallet to drop the fully dressed x-member onto(I chained it up to my truck and dragged it out sideways,the pallet will save your backing plates as they bend easily) Keep in mind the front clip is extremely HEAVY,7 bolts each side and it'll drop right out Ifthe motors still in it you might want to take it apart piece by piece you don't want to be under there when the last bolt comes out T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
05-12-2009, 10:48 AM | #3 |
Re: what do i need
pb blaster , wd40 or any penetrating oil to soak any bolts and a BFG
( big frigen hammer) dont forget a tarp so you dont ruin your Yukons interior and take some one to help you
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
05-12-2009, 09:40 PM | #4 |
Re: what do i need
I think I have everything I need right here. I also have my jack and 4 stands and a porta toarch if things get too nasty.
05-12-2009, 09:59 PM | #5 |
SIR
Re: what do i need
HOWDY HOME BOY!!!,where in g/p do you live?...anyway don't forget safty glasses,small first aid kit,come-a-long,something for wasp stings,and bee's a piece of pipe (for leverage)a box for small parts,keep us posted on your progress......
66long low fleet http://community.webshots.com/user/LVNR66 |
05-12-2009, 10:22 PM | #6 |
Re: what do i need
Hey! I live up by the bowling alley up town. didn't know anyone was on here from grants pass!! also i packed the saftey glasses alredy. god gave me 2 eyes and 10 fingers and i can't go back and get more!
05-12-2009, 10:37 PM | #7 |
60-66 Nut
Re: what do i need
With what everyone else has mentioned and what you're showing, looks like you've pretty much got it. Couple things I didn't see mentioned is a catch pan for fluids, hand cleaner and towels/rags. It is always nice to have help when tackling something like this, so if you have a friend with a strong back. And if you do end up dismantling the front suspension, watch out for those springs, they'll getcha if you aren't careful.
05-12-2009, 11:48 PM | #8 |
1 thing at a time is progress.
Re: what do i need
Toilet paper (just in case) also a fire extinguisher if your using a torch around a grease soaked frame. Good luck
Alan
Philippians 2:14-16 |
05-13-2009, 12:01 AM | #9 |
Resistance is Futile
Re: what do i need
If you just need to get it home, some issues could be dealt with later, I guess. In your pile of stuff I didnt see a hand sledge (aka=BFH) and a pickle fork. Also if you have pullers; could be handy. Of course you could disassemble big sections of parts and not deal with little issues. EG: Unbolt idler and steering box....pop the tie rods and take it out in one piece....and try not to smash a finger carrying it to the truck.....you get the picture, Im sure. Good luck.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-13-2009, 01:49 AM | #10 |
Re: what do i need
Thanks for the help guys. I've got everything loaded up and I'm heading out Thursday morning to go get it all. I'll post pics in my build thread of what I got.
