05-12-2009, 10:13 AM | #1 |
Symptoms of a bad starter
what are some of the symptoms af a bad starter, or a starter that is going bad?
1972 longbed- 454 1967 shortbed- 355 |
05-12-2009, 10:23 AM | #2 |
Re: Symptoms of a bad starter
you will hear whinning once it spins, click noise when starting..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-12-2009, 12:30 PM | #3 | |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
hi Big_ AL_71, good stuff on here huh?
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: Last edited by seldomseen65; 05-12-2009 at 12:33 PM. |
05-12-2009, 03:16 PM | #4 |
Watch out for your cornhole !
I always rebuild my own starters. I get the parts from O Reilly locally.
To competely redo one, I get both bushings, the starter drive (bendix), 4 brushes, 2 brush springs, and the pivot fork that pushes the drive out. A soleniod isn't usually required as you can flip the washer inside of it to get a new contact surface. I did the one in my beater a month or so ago, and I had right at 45 dollars invested in it, but the end result is much superior to a parts store rebuilt cheapie.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 05-12-2009 at 03:18 PM. |
05-12-2009, 06:04 PM | #5 |
I wish I had the skills of Tx Firefighter. When my starter went out I brought it in as a core to the "zone" and got one with a lifetime warranty. I have a lot of compression so I figure it is a good investment.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
05-12-2009, 06:32 PM | #6 |
No skills at all man. You just disassemble the starter and put it back together with new parts.
05-12-2009, 09:57 PM | #7 | |
spirit rider66
i have a great family now and we have a lift in our shop now and that helps me still work on "The Ghost" when i can't get under the truck any more. and my new wife will not let me get under any cars or trucks any more since we got the lift in the shop. be careful out there Tx.
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: |
05-12-2009, 10:01 PM | #8 |
I do it myself so I know it's done right. Plus, I wanted to detail it and powdercoat it to make it look perfect for a long time.
05-12-2009, 10:10 PM | #9 | |
spirit rider66
hey kevin, remember that guy from NC doing work on his title for his 66-67-??,, truck yesterday he threaded that he finally got'er all done and he had all the paper work done on the truck.
05-12-2009, 10:17 PM | #10 |
05-13-2009, 05:29 AM | #11 |
You can test the amperage draw on your starter. The battery has to be fully charged and in good condition.
The amp reading should be approximately 150-200 amps while cranking. An amprobe clamp over meter of the right range is needed to clamp over the positive cable. Another test that you can do is use a volt meter hooked to your battery while cranking. Voltage should not go below 10 volts. If the battery is good this test will work to tell if a starter is bad. In both tests disconnecting the distributor wire is suggested so the engine won't start. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 05-13-2009 at 05:30 AM. Reason: wording change |
05-13-2009, 05:46 AM | #12 |
There are a few ways the starter or solenoid can go bad.If it appears to have a bad battery,won`t crank,yeat a fresh battery or jump start still won`t get it is one symptom.First check wiring and connections.If ok there,the windings are shot and the starter is drawing more amps than provided by the system.Headers can produce the same symptoms by heating the starter and expanding the works to where it won`t spin.Cold water on it will getcha goin`.You`ll get not even a click when it`s too hot,yet will have full power to lights,horn,wipers,etc.
I always took my bench work (carbs,starters,alternators) to a good shop in my area that specializes.The price was right and top-notch quality.I haven`t checked lately since I`ve heard crazy high rebuild costs all over.If they are up to prices elsewhere I`ll take a good look at doing my own.It was always my time vs cost and cost won.Things are a changin`,tho`.I had been taking my stuff to my buddy`s shop for about 15 years since he was reasonable and good and I was busy doin`what I do.But,I have been doing my own work the last three years with this recession putting a big hurt on my income.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-13-2009 at 05:48 AM. |
