Old 05-12-2009, 08:11 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Here's the Muncie...now do I have to fab a shifter mount ?
The Munice is sitting patiently on my bench (has been for over a week now) for the gaskets and seals to come in.
Notice the shifter assembly...how does this mount to the tranny ??
I'm assuming it originally was mounted in a center console of a car....as I got it from a guy who was going to drop it in a Camaro.
I'm assuming i have to build a mount ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-12-2009, 08:20 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Here's the Muncie...now do I have to fab a shifter mount ?
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-12-2009, 08:57 PM   #3
Mowman
Your missing a cast aluminum piece that mates the shifter to the trans. It bolts on the rear tailstock. You can see the mounting holes in your picture. Bollt on the bracket and then bolt the shifter to that. There are threaded holes in the bracket.
Mowman
Mowman is offline   Reply With Quote
Old 05-12-2009, 08:59 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Mowman.....thanks for the info....I figured that much.
Welcome aboard, I see this is your first post !!!
Should I just fab something up, or is that cast piece available ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-12-2009, 09:15 PM   #5
Mowman
Do a search on evil bay for a muncie mount to see what it looks like. Actually I think the new ones are a stamped steel piece instead of the aluminum part. I got an aluminum one when I ordered my shifter 56 Belair. I've been lurking on here because my son is doing a 61 PU and we have learned quite a bit on here. thanks for the welcome.
Mowman
Old 05-12-2009, 09:19 PM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks will do....
When you get going, start a build thread on here...
If you need any info, this is the place for it !!
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-12-2009, 10:56 PM   #7
rcrahn
rcrahn's Avatar
John,
There is a shifter support plate. I have a nice GTO restoration guide that has plenty of good diagrams on the Hurst 3&4 speed setups mated to M22. Let me know if you would like to borrow it for reference.
Rich
rcrahn is offline   Reply With Quote
Old 05-13-2009, 12:24 AM   #8
Captainfab
60-66 Nut
There are a couple different mounting plates. I think the cast aluminum ones are intended for passenger cars, as they position the shifter lower which is how your shifter rods look they are designed for. There is a fabricated steel bracket that positions the shifter up higher, which is great for our trucks, but it requires shifter rods that are pretty much straight. I can get you a pic if you like Chief.
Old 05-13-2009, 08:54 AM   #9
derider
derider's Avatar
Go to an old school tranny shop they usually have shifters and plates just sitting around. The last one I needed the guy just gave it to me. What seats do you have in your truck? I currently have buckets and an M21 so no shifter issues. I just got a late model 40/20/40 with integrated seat belts and fold down console. I am going to have to fab a "Z" shape adapter to move the shifter stick forward.
derider is offline   Reply With Quote
Old 05-13-2009, 11:51 AM   #10
502tripower
502tripower's Avatar
Chief, This is a inline shifter but it gives you an idea what your looking for. Good luck.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 05-13-2009, 05:18 PM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by rcrahn View Post
John,
Rich
Sweet...can you copy and fax a picture ??
I am running the stock bench.....Not worried too much about the shifter, just need to mount it.
Thanks for the pic....this gives me an idea !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-14-2009, 08:02 PM   #12
Super73
Super73's Avatar
Rocka,
If I can remember, I will be towing my buddies 64 from Hollister to San Leandro next week. I could probably meet up with you along the way. We found a handle sourced through Summit (hurst or something) then I fabed up a bracket to hold it in place. We could pop it out with in minutes and trace it.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-15-2009, 09:27 AM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-15-2009, 01:03 PM   #14
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
That shifter looks like it will work. The bends look just right to clear the seat once the gate is bolted to the back of the tranny.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 05-15-2009, 04:56 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I think so too....
I'm just gonna fab up something...I was just trying to be lazy !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-15-2009, 08:35 PM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I did some more searching...and found different install kits for Hurst shifters.
They list different mounts and levers for Pontiacs, Vettes, Camaros, etc.
Looking at the pics...it seem the kit intended for the "Vette" places the shifter the closest to the front....
Anyone have any thoughts on this ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
