Cross over - steering box
Which 2WD steering box should I use for my cross over kit on my 1972 GMC Jimmy?
72 GMC Jimmy, 350, sm465 np205 (getting a face lift) 64 Nova SS, 327 SC & gassed, TH350. (blowed it up) 84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike) 96 HD FatBoy evo with 102hp/100tq (mine!) KEEP NOTHING STOCK! |
Grease Monkey
Re: Cross over - steering box
A 1972 2wd steering box. Thats what I used
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Help me out, What is a crossover kit?
1971 GMC ![]() 1972 Small Blocked DATSUN 240Z Dads old car ![]() |
Grease Monkey
This is cross over steering
![]() ![]() ![]() ![]() Any questions?
Looks rather simple
the pollock
dude i like your steering stabalizer set up way more then mine
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You can use any '69-'87 C10 steering box. Just be sure to get one that has the same style fittings as your current pump has. In around 1981 oer so they switched to metric fittings with O-rings instead of the double flare.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-12-2009 at 10:41 PM. |
#8 | |
You could always change the fitting on the back of the pump to match whatever high pressure hose you have coming off the steering box.
My builds 69 stepside.......2wd to 4wd http://67-72chevytrucks.com/vboard/s...d.php?t=330675 and the new 66 http://67-72chevytrucks.com/vboard/s...d.php?t=302321 |
![]() Join Date: Oct 2006
The mid 70s boxes and newer went to a closer ratio( fewer turns lock to lock), these are the ones I like, it makes these trucks feel more sporty and less like a dump truck.
All you need is the sector shaft out of a 2wd box.
No need to replace the whole box. Yes, the later years have a faster ratio, which is nice. But with crossover everything is a new calculation, ie lengh of pitman arm, length of arm on axle, box, sector shaft, new or old box. Once you go crossover you'll wonder why you took so long to make the change. I've always said it "be carefull letting your friends or girlfriends drive your truck after the conversion" it will turn fast and sharp and if your not REALLY used to a big tall truck, funny things could happen. Mick |
And then there is cross-over w/High steer and Hydro Assit
![]() ![]() Moves the Tie-rod up high out of the way (black) crossover is green. Wheeling in the rocks with crossover can be a b**th to steer so the Hydro makes for one finger steering ![]() ![]() Tapped 2wd gearbox to work the hydro ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Yes, I want that next.
Is there a kit or just pieces? Dana 60 with cross over now... Mick |
#13 |
the pollock
OMG burt!
i want.. hey my birthday is in the near future... he he he
#14 |
60-66 Nut
This is true, but first you would need the fitting and the most likely place to get one is another pump. I was just trying to save the OP one more thing to do....
#15 |
60-66 Nut
Do you know how many turns lock to lock they are compared to the early ones?
#16 | |
![]() ![]() ![]() By the way if you have crossover and a locker up front, steering in 4x4 mode can get hmmm..less than smooth or just plain bad = hang on. before I installed Hydroassit I had to switch from 4x4 to 2x4 when I drove at any speed higher than second gear. I HIGHLY recomend Hydroassit if you plan on running a locker up front w/crossover = one finger steering ![]() .02c
#17 | |
Lots of companies selling sets, first round I used ORD and the 2nd version I went with Ballistic Fab. There's allows the spring to be deleted, hence no more death wobble. (if your running a D60) http://www.ballisticfabrication.com/...axx=300&maxy=0 Cross over should look something like this, both should be parallel |
#18 |
Sorry ericpost, got off topic.
Later model boxes offer a closer ratio steering rate and are considered more desirable box but I'm not sure what year the input shaft changes. |
#19 | |
So anyway where would I get a sector shaft and the needed seals to replace the 4wd sector shaft. Oh and I'm going with high steer as well ;-)
