Tips on filling my transfer case
I have a 91 fullsize Blazer 4X4.The transfer case leaks alot.I'm eventually going to rebuild.Until then I'm just going to keep adding fluid.My question is,what's the best way to fill it?I keep ending up with atf all over my garage floor.
Re: Tips on filling my transfer case
The best way is to use a pump. The way I usually do it is to use the top off of a gear lube bottle. They will usually screw right on the ATF bottle. Then shove a piece of hose over the nozzle. Use a long enough hose so that you can easily get the bottle positioned higher than the fill plug. Shove the hose in the hole and squeeze it in.
Tim |
