14 bolt vs Dana 60
If you guys have seen my other post I am looking at buying a new 71-72 4x4. I have found 72 GMC with a Dana 60 rear axle. I was also making arrangements to buy a 14 bolt from a 77 1 ton for my project. WHat do you guys think. Thanks
Used to have a truck
Much better parts availabilty with the dana 60. The 14 bolt has a larger ring gear but the dana 60's is large enough. At least with the posi carriers the Dana 60 carrier is substantially stronger than the 14 bolts. Ive used some that were going on 40 years old that worked as good as when they were new. You might even consider a dana 70 if you want 35 spline axles.
Ever seen a 14 bolt under a championship drag race car?
No truck :-( |
I know from around here the guys who have pulling trucks say the 14 bolt is much stronger than the dana 60 in the axles. The 60 axles will twist into. I have never noticed any of them using the 60 in the rear. I even see the ford guys using 14 bolts.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
Born Psycho
![]() Join Date: Feb 2001
14 bolt full floaters are stronger all the way around, the axle shafts in a dana 60 aren't much bigger than a 12 bolt. i've seen a lot of broken axle shafts in 60s. parts for 14 bolts are readily available, every 3/4 ton or 1 ton got a full floater 14 bolt from 73 up to ???
there's even a newer version with rear discs if you so desire or rear disc conversions for the drum brake units.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Aren't the 14 bolt pinion shafts supported by three bearings instead of two like the 60?
Eric 1969 K20, 465/205 package |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
One advantage of the D60 in a 4x4 is increased ground clearance over the 14 bolt.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
that right. you can shave a 14 bolt to gain some back.....ive seen it done alot.
My other Love
Well one problem I can see with using a corporate on your truck is the placement of the shock mounts. I like 14 bolts, never broke one yet. I have seen a few Dana 60 axles break before.
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
I guess it all depends on what your driving style is. Is the 14 bolt stronger? Yes, but it also weighs about 200 pounds more then a 60, and hangs lower by about 1 1/2 inches. Unless, I really planned on wheelin the pee outta my truck, I wouldnt waste my time swapping a 14 bolt in over a 60.
