Old 05-13-2009, 09:03 AM   #1
Mark B
Mark B's Avatar
removing rubber trim around steering column
How do I remove the rubber trim around the steering column? (The trim that fits into the instrument panel). I see it slides off. Do I need to dismantel the all the switch and shift parts at the top of the column to get the rubber trim off? I don't want to cut it off because I want to clean it up and paint it. I have the steering wheel out and the instrument panel removed right now, and shifter is 3 on the tree.
thanks
Mark
Mark B is offline   Reply With Quote
Old 05-13-2009, 10:28 AM   #2
cdowns
cdowns's Avatar
Re: removing rubber trim around steering column
take column out of truck
Old 05-13-2009, 09:36 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I split mine at the bottom, painted it and put it back on. It is covered by the trim plate on the bottom. I used Fusion paint for plastics. No idea how long it will stay on...
LockDoc
Leon
