Old 05-13-2009, 12:13 PM   #1
1966gmc
Why does it taste purple?
1966gmc's Avatar
URGENT HELP needed.....tail light problem
I need help with this asap as I am taking this truck on a weekend long cruise trip. I have no tail lights but my brake lights and turn signals work perfectly. I am stumped on this and have no time to completely re-wire the rear end of this thing by tomorrow morning. I am on a lunch break as I type this plea for help. I am sure this is not a ground issue due to the rest of the lights working condition. Help a brother out
Hello, my name is John and I'm a truckaholic
1966gmc is offline   Reply With Quote
Old 05-13-2009, 12:18 PM   #2
jason65
Registerd User
jason65's Avatar
Re: URGENT HELP needed.....tail light problem
Do you have front park lights? Give them the wiggle test.
jason65 is offline   Reply With Quote
Old 05-13-2009, 12:30 PM   #3
70 Suburban
Rods
Do you have dash lights?
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 05-13-2009, 12:41 PM   #4
jchav62
1962 C-10
jchav62's Avatar
Have you checked the bulbs?
One time on my buddy's '60, the tail lights weren't working, with the lights on, we shook and wiggled the tailgate and magically they came back on.... I believe it was a ground issue that the vibration from shaking the tailgate fixed.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-13-2009, 12:59 PM   #5
joe231
joe231's Avatar
yeah, more info needed?
have you checked for voltage at the rear lights?
have you checked fuses?
do you have a license plate light?
as you probably know the brake/turn is one circuit and the taillights are another.....
CHEVY ONLY
Old 05-13-2009, 01:09 PM   #6
1966gmc
1966gmc's Avatar
ok sorry.yes i have front parking lights. I dont have dash lights and no tag lights. I have 12 volts across all fuses and the bulbs are brand new. No voltage at the rear lights until I hit the brakes
Old 05-13-2009, 01:12 PM   #7
70 Suburban
Rods
dash lights a common to tell you there is no power to the rear of the truck (incomplete circut).
Old 05-13-2009, 01:26 PM   #8
joe231
joe231's Avatar
the dash and the dome are the same circuit, the dash lights are not on the circuit with the taillights. also the taillights and the front park lights are on a separate circuit I think, if it is the same as the 64-65, not sure if there was a change in 66
check for power at the headlight switch, the '64 diagram show a brown wire there.
if you have power there, then check the firewall connector, if there is power there, then check the connector under the rear of the bed....
if you have no power at the switch, then I would suspect the switch itself.
CHEVY ONLY
Old 05-13-2009, 02:30 PM   #9
1966gmc
1966gmc's Avatar
So I take it that the tail lamps are grounded at the bezel?
Old 05-13-2009, 02:37 PM   #10
70 Suburban
Rods
YES. BUT IF IT WERE A GROUND THEN YOU WOULD HAVE ALTERNATING FLASHING OR DIM FLASHING WHE YOU USE YOUR BLINKER. ALS DIM BRAKE LIGHTS WHEN YOU HVE NO GROUND.. i WOULD START AT YOUR DASH SWITCH.. THATS COMMON
Old 05-13-2009, 03:33 PM   #11
joe231
joe231's Avatar
man, why are you yelling?
yes the the tail lights ground through the socket/bucket....but as stated it should be grounded ok if your brake and turn works, unless they are very dim..
CHEVY ONLY
Old 05-13-2009, 03:35 PM   #12
70 Suburban
Rods
sorry I am in a service dpt. they like everything to be in caps
Old 05-13-2009, 03:36 PM   #13
joe231
joe231's Avatar
CHEVY ONLY
Old 05-13-2009, 03:41 PM   #14
70 Suburban
Rods
lol if you look I did push shift for the (i)
Old 05-13-2009, 03:42 PM   #15
joe231
joe231's Avatar
I see that now
CHEVY ONLY
Old 05-13-2009, 07:07 PM   #16
1966gmc
1966gmc's Avatar
Broken wire. Re-wired the rear and good as gold. Thanks guys
Old 05-13-2009, 07:12 PM   #17
Joemomma1
Joemomma1's Avatar
I know this is off topic but how about some pics of that bad boy?
Joemomma1 is offline   Reply With Quote
Old 05-13-2009, 07:32 PM   #18
joe231
joe231's Avatar
right on, glad to hear it
CHEVY ONLY
Old 05-13-2009, 08:24 PM   #19
1966gmc
1966gmc's Avatar
Man I hate electrical problems. Thanks again guys
Page 1 and 2 have some older pics. I will more than likely take some newer pics this weekend
http://s12.photobucket.com/albums/a224/05xd/
