Old 05-13-2009, 01:58 PM   #1
Kim57
Kim57's Avatar
Door repair ?'s
#1- I need to replace the lower portion of my passenger door.
The new patch panel doesn't have the recesses in the jambs that the originals do.
As you can see in the pics the lower hinge replacement bracket has a step in it for the recess.
Have any of you had to replace the lower door and hinge mounting bracket and what did you do?
#2- On my drivers door the upper hinge nuts have fallen off. Other than that the door is in good condition. They don't make a replacement bracket so I have to replace the nuts.
option 1 would be to cut an access panel on the outer door skin and just weld some nuts on the bracket.
Option 2 would be to cut the bracket and inner door panel out and do it that way.
Just looking for some opinions on how you guys might do it.
Kim
Kim57 is offline   Reply With Quote
Old 05-13-2009, 02:03 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Door repair ?'s
Kim look at my cardomain site I have done this. Second question I brought some cage nuts, how many do you need? I see how many I have left.
Kabwe is offline   Reply With Quote
Old 05-13-2009, 02:12 PM   #3
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Door repair ?'s
Here is an old thread I made of how I repaired my doors.
http://67-72chevytrucks.com/vboard/s...d.php?t=221682
Here is what the bolts look like that I replaced the originals with.
Old 05-13-2009, 02:24 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Door repair ?'s
Oh and by the way no cutting the pillar with those cage nuts. I use the screw to hold it in place drilled two 1/8 holes and plug welded them in place. I hope this helps.
Old 05-13-2009, 03:32 PM   #5
Kim57
Kim57's Avatar
Re: Door repair ?'s
Kabwe
Thanks for the replies.
The nuts that fell off are the ones that hold the hinge to the door.
Did your lower inside patch panel have the recesses in it that the original doors have on the jamb?
Mine is smooth.
I think I can get by just cutting the step on the new bracket off.
Kim
Old 05-13-2009, 05:37 PM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Door repair ?'s
Mine were like the originals they had the recess. I got mine from brothers.
Old 05-14-2009, 12:12 AM   #7
Kim57
Kim57's Avatar
Re: Door repair ?'s
I got mine at Brothers also.
I'm gonna have to give them a call and see if they changed vendors.
Kim
Old 05-14-2009, 08:20 AM   #8
renegade6
Re: Door repair ?'s
Where did you buy the cage nuts?
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 05-14-2009, 10:05 AM   #9
Kim57
Kim57's Avatar
Re: Door repair ?'s
These guys have them.
Kim
http://www.mcmaster.com/#weld-nuts/=1vcg10
