Old 05-13-2009, 05:47 PM   #1
kenny_strong
kenny_strong's Avatar
chevy donor truck
I know where a 1994 chevy 3500 is sitting. It has a GM rebuilt automatic trans (1.5 years ago)and a 350 engine with 115,000 miles. I am thinking about making him an offer and using the engine, trans and transfer case in my 66. Also may use the seat and A/C system out of it too.
Any thoughts on this year running gear? Worth the swap?
Value?
Thanks in advance for your help.
kenny_strong is offline   Reply With Quote
Old 05-13-2009, 09:06 PM   #2
duallyjams
duallyjams's Avatar
Re: chevy donor truck
Where in Md are you?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-13-2009, 10:13 PM   #3
joe231
joe231's Avatar
the t-case is a driver's side drop, you will need a ford front diff to use it as it sits stock...
you running 8 lug axles?
CHEVY ONLY
Old 05-14-2009, 12:25 AM   #4
Captainfab
60-66 Nut
There's nothing wrong with that drivetrain, it should be a good setup. As Joe said the TC will be a drivers drop. There is a TC that will interchange with that one that is a pass drop.....I just don't remember which one it is.....a 241 maybe? Are you going to keep the engine a TBI?
Old 05-14-2009, 05:50 AM   #5
kenny_strong
Sounds like the transfer case may cause a good bit of headaches.
I am just looking to upgrade because the motor in my truck now needs rebuilt and if I rebuild the 94 it already has all of the belts/pullys and ac compressor ready to go.
I still have 8 lug axles.
I am in Middletown, between Frederick and Hagerstown. Where is Deale? I wouldnt mind seeing your GMC dash in person, mine has been chopped to hell by the PO.
