Old 05-13-2009, 09:04 PM   #1
East End K5
electric choke wire color
Rather than ask a FAQ, and to save some time, anybody know what color the choke wire is per say a 1986 v8? I put a meter on 2 wires I thought may have been but.... no juice in the accessory position...
Thx,
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 05-14-2009, 06:33 AM   #2
James McClure
One shot, one kill.
Re: electric choke wire color
Bill, I do believe the wire to be pink and come from an oil pressure switch at the back of the engine under the distributor. I do know the wire will only be hot with the engine running. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 05-14-2009, 08:36 AM   #3
sierra4x4
sierra4x4's Avatar
All the ones I've seen here in Canada have been lt blue, but usually faded to a green color ftom engine heat.
sierra4x4 is offline   Reply With Quote
Old 05-14-2009, 09:12 AM   #4
Tony@AirRideTech
Junior Member
the ones I remember are blue / green like sierra mentioned.... with trucks these old and as many hacks have gotten a hold of them... it could be any color that bulk primary wire is available in.
Tony@AirRideTech is offline   Reply With Quote
Old 05-14-2009, 01:49 PM   #5
tgh117
Crazy
tgh117's Avatar
Mine is a greenish color, comes from back behind the oil pressure sender and is hot as long as the key is in the on position. Its only a single spade connector, as the ground from the choke comes from elsewhere. If you are using an aftermarket carb, they recommend a 12 volt source and not the factory wire, but I use it and it seems to work fine. If I can I will grab a picture of mine for you.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 05-14-2009, 07:00 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
The choke wire will NOT have power on the acc. side.
powerdriver 1958 is offline   Reply With Quote
