Old 05-13-2009, 09:45 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
side fill (under bed) tank
hello all, when i get a gas tank for under the bed i want a side fill because i still use my truck as a truck(last weekend had 4500lbs of oak firewood in it) would be out of luck with a bed fill lol
any way i wanted to know if i could buy a stock blazer/burben filler hose/neck and use it? from the tank to the side of the bed?
thanks
Nate
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 05-13-2009, 10:22 PM   #2
Putter
More Cowbell....
Putter's Avatar
Re: side fill (under bed) tank
Can we assume yours is a FLEET bed and not a stepper?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-13-2009, 10:47 PM   #3
425HP409
425hp409
425HP409's Avatar
I did just what you want to do to my 68 short wide bed. I bought the under the bed tank kit from LMC and I bought the behind the seat tank fill kit from Classic Industries for a 55-59 Pickup. I mounted the tank under the bed reinforcement which necessitated drilling holes in the frame. If I did it again I would modify the reinforcement so that I could mount the tank higher. I then installed the Classic kit to the tank and secured it to the bed of the truck. I can simply fill the tank now from under the fender behind the left rear tire. I can post pictures next week, or email them to you when I get home from vacation.
Charles
425HP409 is offline   Reply With Quote
Old 05-14-2009, 09:16 AM   #4
nrb's70gmc
nrb's70gmc's Avatar
yes its a fleet
Old 05-14-2009, 09:18 AM   #5
nrb's70gmc
nrb's70gmc's Avatar
Charles
ya pictures would be great
Old 05-28-2009, 08:08 PM   #6
ShortStepper
ShortStepper's Avatar
Lets see some ideas & photos for step side trucks.
ShortStepper is offline   Reply With Quote
