Old 05-13-2009, 09:50 PM   #1
69halfton
69halfton's Avatar
Brake Light (in dash)
so ive noticed the brakes on my truck starting to feel funny. if I stop at a stop light, i can firmly push the pedal, and have the pedal slowly just go to the floor. also with my foot on the brake at a light, the pressure will slowly bleed down, and the truck will start to creep forwars, and i have to apply more pedal pressure to hold the truck. so i just figured that it was time for a new master cylinder (it has started to leak a little since the problem developed)
today, the brake warning light on the dash came on, first time ive ever seen. its only on when i have alot of pedal pressure on during braking, and i can make it flicker with my foot at a stoplight.
my question is... a) confirm this sounds like a master cylinder issue?
b) what is the brake indicatior light measuring for? or what makes the light come on? (i.e high/low pressure in the resivoir or..?) ..just for my own curiosity
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 05-13-2009, 10:11 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Brake Light (in dash)
The light means there is unequal pressure in your brake system, front to back. I would check for a leaking brake line or wheel cylinder.... I would not drive it until you find the problem and correct it...
LockDoc
Leon
Old 05-13-2009, 10:14 PM   #3
Putter
More Cowbell....
Putter's Avatar
Not arguing, but I thought it came on when the fluid level dropped below a certain level.
If you are pushing hard enough on the pedal to use all the fluid (you did mention that it is LEAKING).....then that may cause it.
I only say this because my light has lit once ever...and the MC was dry as a bone.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-13-2009, 10:28 PM   #4
sjarrett71
sjarrett71's Avatar
If you have leaking I would definately replace the master cylinder. If the pedal slowly goes to the floor I would replace the booster too.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-13-2009, 10:45 PM   #5
69halfton
69halfton's Avatar
i checked all the wheel cylinders and lines, and i cant find any wetness except the bottom on the MC. it went nearly dry on me once, and the light never came on, i filled it up a couple weeks ago, and it hasn't really used anymore, but it does still appear to be leaking
when i say pedal goes to the floor, i mean i have to push it pretty hard, and it feels like the fliud it getting around the piston and back to the MC, bleeding pressure down.
i think the booster is fine, it isn't leaking/hissing at me and holds vacuum...
- Jason
Favorite caption:
Old 05-13-2009, 11:04 PM   #6
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
My truck is doing the same thing. Fluid level is full and has been. I figured it was time to have them adjusted.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 05-13-2009, 11:18 PM   #7
highperf4x4
It's a master cylinder issue. When your brake pedal bleeds off while you're stopped it's fluid exiting somewhere. If it was at the wheels it would be all over the inside of the rim and tire. Your proportioning valve beneath the master cylinder is what's setting your light off. When your pedal moves far enough it fails to throw enough fluid to the rears and the pressure becomes unequalized.
If you're going to drive it without replacing the master cylinder keep a very close eye on your fluid level.
When you put the new master cylinder on be sure you bench bleed it before you hook it up to the brake lines. If the inner shaft moves more than 1" or so before the air has been evacuated from the shaft chamber it will damage the seals.
highperf4x4 is offline   Reply With Quote
Old 05-13-2009, 11:21 PM   #8
Longhorn321
Size Matters
Longhorn321's Avatar
The M/C could have a leak internally causing your pedal to slowly go to the floor. This can happen and there may not be a visible sign outside....its just leaking by the seals on the piston, not the seal to the outside. If you hit 'em hard do you have a good firm pedal?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 05-13-2009, 11:23 PM   #9
highperf4x4
If your booster is failing, the pedal will become much harder to push.
Old 05-14-2009, 12:00 AM   #10
mixermike
mixermike's Avatar
mixermike is offline   Reply With Quote
Old 05-14-2009, 12:13 AM   #11
highperf4x4
Right and he said he can actually see brake fluid leaking from the back of the master cylinder so it's a sure thing.
Old 05-14-2009, 12:20 AM   #12
highperf4x4
Wait, are you referring to Richard8971 or the original poster? In Richards case you could be right. It's a good possibility. My comments were directed at the original poster.
Old 05-14-2009, 12:46 AM   #13
CMACDONALD1
CMACDONALD1's Avatar
I'am having these same symptoms with one of my trucks, if i hit the brakes real hard i have brakes but if i'am stoped at a light with minimal amount of pressure applied on the brake it will go to the floor and start to creep ahead but if i let off and hit it again i have brakes. I think it is the master cylinder myself but i guess i will soon find out as i just got another master to put in it. hopefuly within the next few days i can find time to get it installed and let you know.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 05-14-2009, 01:01 AM   #14
highperf4x4
Make sure you bench bleed it first!
Old 05-14-2009, 08:26 AM   #15
Longhorn321
Size Matters
Either one. The OP said the M/C was a little wet but it had not gone dry recently.
I would bet from your description that you will fix it with the M/C.
...WOOOO HOOOO!!!!
Old 05-14-2009, 09:33 AM   #16
bowtie72
bowtie72's Avatar
Normally you can pump the pedal with engine off or on. The pedal should hold firm. If not the master cylinder is likely bypassing internally. Cure replace master cylinder. Light comes on due to perportioning valve. When the valve senses a difference in pressure from front to back the valves moves and turnes the light on. This is cured by bleeding the brakes at the valve. But if the m/c is leaking internally it will cause the valve to move. Hopefully I explained this so you can understand it. Good luck
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 05-14-2009, 11:57 AM   #17
CMACDONALD1
hey 69halfton I just replaced my master cylider this morning and problem went away hope this helps as my problem sounded very similar to yours. I love it when things work out!!
1959 "Henry"
1966 Biscayne
1972 Suburban
Old 05-14-2009, 03:08 PM   #18
69halfton
69halfton's Avatar
pretty much what i figured. from all your responses im sure its the MC now. if i hit the pedal hard i have plenty of prssure, meaning it is by passing internally and cant escape fast enough...therefore i have plenty of brake pedal. im going to keep on trucking until the MC comes in and then make the swap. thanks for the help everyone...
- Jason
Favorite caption:
Old 05-14-2009, 05:37 PM   #19
highperf4x4
Don't thank me till you get the bill...........
I got that from Joe231!!
Old 05-14-2009, 09:15 PM   #20
Richard8971
I have a power brake booster from a newer S-10 pickup. No leakage that I can see... Fluid level is still good. They feel squishy and will lock the wheels if I need to stop quickly. It's getting scary to drive!
I just replaced the back cylinders and bled the system recently. The fluid level is the same now as it was then. Full.
D
Sherlock Holmes
Old 05-14-2009, 10:54 PM   #21
Longhorn321
Size Matters
D
Sounds like you need a M/C too. If there is no fluid leaking out, then it must be leaking internally. When you need to stop quickly, you stab the brakes and the seals flare out, you make pressure and either the front or the back lock. If you ease on the brakes on the other hand....squishy because the seal is not flaring out, it's letting fluid by.
...WOOOO HOOOO!!!!
Old 05-14-2009, 11:40 PM   #22
tim21391
tim21391's Avatar
mine came on in my 72 and so i took it to sears.. and they hooked it up and found out that my rear brakes needed adjusted... since they told me it would take half hour and it took them about 8 hrs i walked away with paying only fifteen bucks so i cant help you on the price it costs to hook it up to a scanner..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-15-2009, 12:43 AM   #23
highperf4x4
What did they scan Tim? Your 72 doesn't have a computer, maybe they were pulling your leg.
Old 05-15-2009, 01:25 AM   #24
MonteSS454
MonteSS454's Avatar
My thoughts also.
MonteSS454 is offline   Reply With Quote
Old 05-15-2009, 08:48 AM   #25
Longhorn321
Size Matters
Originally Posted by MonteSS454 View Post
My thoughts also.
Me too. I was gonna post last night but I was at a loss for words.
...WOOOO HOOOO!!!!
