Old 05-14-2009, 10:29 AM   #1
blazer2007
trying to find a step notch
I want a bolt in step notch but not as high as the ones I,ve found,I would like one that basically sits on top of the frame ,just need that 3-4 inches,already have a c notch but not enough
blazer2007 is offline   Reply With Quote
Old 05-15-2009, 10:45 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: trying to fine step notch
Who have you checked with so far?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-16-2009, 09:50 AM   #3
blazer2007
Re: trying to find a step notch
s.d cp looked in art cataloge,all I can find are 8 inch and up
Old 05-16-2009, 08:27 PM   #4
XXL
Señor Member
XXL's Avatar
You can cut them down.
XXL is offline   Reply With Quote
Old 05-17-2009, 10:04 AM   #5
Rokcrln
Rokcrln's Avatar
I don't think you will find a bolt in Notch that small. The standard is the 3" style and larger than that will be a weld in that as XXL said you can cut down to what ever size you want. This is because most people start off with a small bolt in notch thinking that will be enough As we all know that normally leeds to a larger notch that puts you on the ground or in XXL's case 1" under ground!
You might be able to have a shop build you a larger bolt in notch but it would be 2-3x the amount to have a weld in notch set up for you.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-17-2009, 07:11 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Porterbuilt will make you a bolt in step any size you want...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-18-2009, 09:50 AM   #7
blazer2007
ok thanks, I thought I saw a pic of one on here,but can,t find it now,should be easy to get one made
