Old 05-14-2009, 01:32 PM   #1
Tony_SS
Tony_SS's Avatar
Question Oil Pressure went to 0 today
Hi guys..
I started my truck and the gauge read 0. It slightly moves a little but not much.
Any ideas? Could it be the gauge itself or the sender?
What's involved with changing out the sending unit?
TIA
Tony_SS is offline   Reply With Quote
Old 05-14-2009, 02:41 PM   #2
78BO
78BO's Avatar
Re: Oil Pressure went to 0 today
If I remember right it just screws in/out.
78BO is offline   Reply With Quote
Old 05-14-2009, 03:07 PM   #3
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
try to find a mechanical gauge just to make sure that your pump didn't go out. then, if all is good. then go with the sending unit, I think there about ten bucks or about. if it still is reading bad, trace the wires to your gauge and make sure they aren't cut or shorting out. then if all is still good then my guess would be the gauge its self.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-14-2009, 04:06 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Ditto on getting a mechanical gauge to check it out, first.
piecesparts is offline   Reply With Quote
Old 05-14-2009, 05:43 PM   #5
Prong
Pull the lead off the sender and turn the ignition on. It should peg way past 60. Reconnect the lead and turn the ignition on. It should read 0 or very close to it. If it passes these 2 tests, the gauge is most likely ok.
Prong is offline   Reply With Quote
Old 05-14-2009, 06:27 PM   #6
88 Dippy
88 Dippy's Avatar
how is the oil level? my truck doese this when it is 1qt low
(i have a hole in my pan and it burns oil i go though a lot)
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 05-14-2009, 09:13 PM   #7
Tony_SS
Tony_SS's Avatar
Thanks for the help so far. I will check the gauge. But I think its reading right.
So I let the truck cool and started it back up to drive it home. Oil pressure was 30psi for about 3 miles then gradually went down to 0. Could this still be a bad sender or something else?
Still no sounds or burning oil smell. Oil level has been checked and is ok. I need transportation but don't want to blow the engine if this is serious.
Old 05-14-2009, 10:34 PM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
still could be the sender
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-14-2009, 11:11 PM   #9
heavychevy79
Cheyenne Super
heavychevy79's Avatar
I replaced an old leaking one, and the new one showed 5-10 psi less than the old one.
heavychevy79 is offline   Reply With Quote
Old 05-15-2009, 06:19 AM   #10
billnorman
Sounds like a stuck pressure relief valve... perhaps a piece of debris in it. One Q&D way to fix this without pulling the pan is start it up cold, let it run about 30 secs, and IF you have oil pressure of 30 or so, rev the dinkus out of it, like zoom, zoom, zoom. The high pressure oil when cold rushing out of the relief valve will open it all the way, and wash the particle out. Alternate way 2 is add a can of Seafoam, and do the above. Seafoam is really good at cleaning things. I think you're supposed to take it out (change your oil) soon thereafter. The above is my opinion, don't sue me if it explodes.
billnorman is offline   Reply With Quote
Old 05-15-2009, 10:19 AM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
Sounds like a sender, They were bad for that. I would go pick one up and put it in, its fairly easy.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-15-2009, 01:52 PM   #12
Tony_SS
Tony_SS's Avatar
Well all my tools are packed up since we are moving soon so I dropped it off. The shop told me is was a bad switch and they are also able to fix those rattling brake calipers thank god! So I let them do the job.. I"m just happy its nothing major, just $180 parts and labor.
