![]() Join Date: Oct 2006
Bed side gas filler door
This is probably a stupid question but my truck has one of those screw in filler doors to access my saddle tank. (Yes, they cut a big hole in my bedside) I have finally hooked up my tank and am using it but I have to unscrew the door hinge to access the fuel cap because it is old, beat up, and I have no key to the door part. Does anyone know where you can get these door setups?
I would really like to make it a more solid billet type if possible but I cannot find one anywhere. I have done many searches but am not getting the right word combination. Any ideas? |
Moderator
![]() Join Date: May 2007
Re: Bed side gas filler door
What does it measure? If it is 7.5" x 7.5" square, you can get a nice chrome door from an RV store. Never seen a billet one that is the right size for our trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Thanks. I will have to measure it when I get home but that sounds about right.
member #16
![]() Join Date: Dec 1999
Heres a source.
http://www.pakindustries.com/tank_door_info.html
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 05-14-2009 at 04:06 PM. |
Perfect. Thanks.
Looks good at 20-ft .....
My local hardware storfe sells keyed replacement locks. If you can't find a new door, just put a new lock into your old one.
There's probably a U-shaped spring metal piece that slides into a groove on each side of the lock cylinder on the backside of the door. Not very much $$$$ at all - maybe 5 bucks or so ......... |
#7 | |
Moderator
