Old 05-14-2009, 05:12 PM   #1
83_383Stroker
83_383Stroker's Avatar
lost a rod, need some advise!
so I went to start my truck the other day (1983 c-10 383stroker.)
And heard a "knocking" so after pulling the valve covers I discovered that every one of my roller rockers was lose. one of them was missing the rod. i looked down inside the head and saw the rod down in the valley. So I plan to replace all the rods. does anyone recommend a good brand of rods that are easy on the wallet, and what are the torque specs for the rockers? Thanks!
83' internally ballanced 383 Stroker, 400 turbo 3800 stall , Posi, 750cfm carb, Weind manifold, long tube headers, and a handful of other goodies. Custom billet and woodgrain interior.
83_383Stroker is offline   Reply With Quote
Old 05-14-2009, 06:50 PM   #2
TwinTurbo
TwinTurbo's Avatar
Re: lost a rod, need some advise!
Sounds like the problem is not your pushrods but more likely the locking nuts (either friction or poly locks)
The rockers don't have torque specs, you tighten the nuts to the proper valve lash. If you have friction nuts, do not reuse them, get a fresh set otherwise they will loosen up on you, if you have roller rockers they normally come with poly locks that have an allen set screw inside, loosen the set screw, adjust the lash and then tighten the set screw to lock the nut in place.
TwinTurbo is offline   Reply With Quote
